Like George Cuthbertson?I can't help you if you can not see potential problems when an egotistic owner of a boat building company appoints himself as the chief designer.
Sounds like it discovered a rock. I realize no other boats would have sustained any damage, so this must be a bad build.There is a Top Ten Sailboat Designers List?
To the OP. Caveat Emptor The following comments were made after surveying a 2003 C&C 99:
Upon hauling the vessel it was discovered that there was major keel stub/keel box damage. The keel stub an integral part of the hull structure was noted to be fractured at the root forward section and movement was visible when the keel portion of the ballast package was moved. Some hull panel flexure adjacent the keel stub was also noted.
Further discovery was effected by removal of the cabin sole. It was found that the keel floor reinforcement system had become detached from the hull panel and keel stud/sump.
The following comments were made after surveying a 2013 C&C 101:
Visual observation of the keel studs immediately revealed visible movement of the hull skin as the vessel heeled under dynamic loading. It was clearly evident that the hull skin/ was moving in concert with the keel studs as a direct result of the loads of the keel installation. The Grid structure was not being properly utilized to distribute the loads of the keel as was the design intention. All loading was clearly centralized to the hull skin. Fracturing of the Fiberglass Reinforced Plastic laminates was also observed and clearly seen to be working under sailing loads. As the sailing sea trial continued water was observed weeping in via several of the keel studs. The sailing sea trial was concluded and the vessel returned to the slip.
Now that said, I am sure the above does not apply to all C&C yachts although the QC seems to have been hit and miss in my experience and I know of a C&C 115 that has been raced well in SoCal with good results. I don't know what condition the keel structure is in though.
Good luck.
Serious question: what's wrong with you? Why do you magnify a simple difference of opinion into a death cage match with "two men in one man out" ?
Fuctifino looks to to be an appropriate location for you. Certainlyreadingcomprehensionislacking.Sounds like it discovered a rock. I realize no other boats would have sustained any damage, so this must be a bad build.
Ummmmmm..... I think there was a bit of purple font missing from his post, that probably didn't need to be there for the rest of us, but maybe you needed it?Fuctifino looks to to be an appropriate location for you. Certainlyreadingcomprehensionislacking.
Learjet for me.Ummmmmm..... I think there was a bit of purple font missing from his post, that probably didn't need to be there for the rest of us, but maybe you needed it?
I think he was saying "if you hit a rock and damage the laminate, you can't blame it on the build" in a facetious way. The survey report does not make it clear whether the boat did or did not hit a rock. It may not have, which would then make the damage a build or design issue, but it wasn't explicitly stated.Learjet for me.
Again, reading comprehension is the current cause of loss in this thread. Nowhere was it written that a bulb or keel bottom section sustained a grounding impact, Primarily because they were not.I think he was saying "if you hit a rock and damage the laminate, you can't blame it on the build" in a facetious way. The survey report does not make it clear whether the boat did or did not hit a rock. It may not have, which would then make the damage a build or design issue, but it wasn't explicitly stated.
The fact that there was a fracture at the stub root at the front of the keel suggests a grounding more than a build issue. Hope this explanation helps clear things up.
In the case of the C&C 99, the entire internal grid structure needed to be re-adhered or re-tabbed to the hull shell on the interior.Can the laminate be repaired by rebedding the keel or does it need to be retabbed? Very interested in the discussion.
