Cabin Sole replacement
I’m replacing the main cabin sole on my Alerion Express 28.  The original is 1/2” ‘teak & holly’ plywood and I’ve bought a sheet of same.
The two removable sections of the original sole are secured to the floors by small elbow catches on the underside.
They’re accessed through 1” ID finger holes in the ply which are finished with 1” ID teak finger pulls glued in place.
They’re accessed through 1” ID finger holes which are finished in the plywood by teak rings glued in place. I think they’re commonly called finger pulls.
I have two questions .
Where can I get those teak rings?  A can only find them in 7/8” ID and that’s tight for my pudgy finger.
Are there other panel fastening gubbins which I might prefer.
slug zitski
1,208
worldwide
I don’t like the hole, teak ring
it ages poorly
I prefer a suction cup for lifting floor boards
ive never found a hold down that I like
Ive used this lift style  they are OK
aircraft panel hold down screws  also work
slug zitski
1,208
worldwide
Fleetwood said:
I specified the 'aircraft panel hold down screws' Slug showed, for my cabin sole.
Removed them soon after, I found them impossible to seat and remove easily.
A simple system of shock cord fastened to the sole,  and  a hook on the side of one of the floors works well for me now.
(You can make up similar teak rings with some scrap timber and a couple of hole saws, any size you like. Not quite as aesthetic, but once sanded smooth will look OK).
Boats move ..temperature , rigging loads
difficult to deal with floorboards, hold downs and this movement
many times it’s better to eliminate removable floorboards and go with a fixed floor and  framed, hinged and locked down hatches  set into this fixed floor
on small boats this may be difficult
allweather
82
baltic
Are there versions suitable for deck hatches?
I need to get my cockpit locker hatches tight and would prefer putting one of these in each corner instead of outside latches. But if water just seeps through the latch itself, then it would be a wasted effort.
slug zitski
1,208
worldwide
Many waterproof deck hatch type hold downs
they use O rings on the shaft penetration
do a google search
avoid cheap stuff , look for US or European brands
DDW
1,093
I also specified the quarter turn fasteners in the picture (the vendor is PYI). I also changed them shortly afterwards. They depend on very accurate depth adjustment as there is nearly zero compliance in the depth grip length. They were impossible to adjust and keep adjusted. This is even with cored carbon fiber floorboards, which should be more stable than wood. I left the finishing ring in place, made new sockets that were simply a threaded hole, and use flat head machine screw in place of the 1/4 fastener. It works, but not as quick access and the screws are not captive in the holes.
SloopJonB
12,340
Great Wet North
Those Dzus fasteners are really only good for sheet metal panels - as noted they require extremely precise alignment.
For panels that require only occasional removal I use these with machine screws.
If you use Robertson or Allen head fasteners you can zip them out in seconds with a cordless screwdriver or drill.
DDW
1,093
Actually real Dzus fasteners are much more tolerant of misalignment and depth variation than the PYI floor anchors. The typical Dzus fastener (they make many types) engages a wire spring and has a lot of compliance. There is another PYI 1/4 turn panel anchor that contains a spring for depth compliance, I used a bunch of those on other panels and they work reasonably well. The floor anchors in contrast have to be exactly on position (that is possible with care) and set to exactly the right depth (that is nearly impossible over time). The only compliance is the compression of a small O ring.
SloopJonB
12,340
Great Wet North
Sounds to me like you never had to open & close the hood of a Triumph TR3. ;) :D
DDW
1,093
If I had a Triumph TR3 I'd leave the hood off for ready access. I did own a Triumph Bonneville for awhile. You could not let it idle on the centerstand or it would walk away and you wouldn't find it again.
Arcot
1
Lund BC
British Ausin in 1968 in a northern Ontario Canadian winter.
Left side front disc brake fractured into 2 pieces and was held together by ice for a while.
Apart from that, the rust and the engine needing a rebuild at 20000 miles it was an excellent car in the snow.
phill_nz
949
internet atm
Not even close.
But plenty bad, I agree. Their ugliness kept me away.
Your comment implies plural. Did you have 2 or 3 so one was always available?
Or just a slow learner? ;)
3
all of the above
and they were a good looking car with great handling and a real pleasure to drive  ... on the occasions they could complete the fuel to movement cycle
did read in the dog and lemon guide they were a winner in all categories .. even scored higher than the amc gremlin .. the reliant robin was classed as a bike .. so didnt count
Quickstep192
157
Chesapeake
I love the TR3. During my research I've read that there are now turnkey electronic fuel injection systems for the older British cars that can actually make them reliable.
