Sent a brand new one.Did they repair the old unit or send you a new one?
If it was NEMA 2000 it couldn't have worked on my autohelm. Much lower bandwidth needed for 0183 and this device has no need for 2000 data calling and sharing. Lastly you can convert up to 2000 through many devices.To not be NMEA 2000 as a new product in 2019 is unacceptable.
That’s great it offers a solution for you, but my point still stands about the unacceptable lack of NMEA 2000. Yes you can get converters, and yes you can force things to play nice, but at this point in time, anything new that I’m purchasing must have NMEA 2000 compatibility period. The only exception would be things links load cells and other more esoteric devices.If it was NEMA 2000 it couldn't have worked on my autohelm. Much lower bandwidth needed for 0183 and this device has no need for 2000 data calling and sharing. Lastly you can convert up to 2000 through many devices.
Sorry about the delay on posting.Kaimana - how did it go with the Calypso in October?
Not really advisable to steer to a derivative calculation unless you have it calibrated on a regular basis. Errors creep in everywhere. And then there is the built in lag time. You can get pretty lost trying to chase a TWA on an instrument that has a 30-second rolling average using data from sensors that also are averaging their output.Use TWA downwind.
So in other words, not very accurate at all, at the low end.Here's something more believable.. though of course the accuracy will depend on the particular implementation.
http://www.apptech.com/products/ultrasonic-anemometers/trisonica-mini/
Accuracy
±0.5 m/s for low range wind speed
±2% for high range wind speed
±1.0 degrees for wind direction
I've been considering one to put on the mast of the 505 I sail as a way to get wind speed and direction data from a compact unit with no moving parts. The aim being to feed that data into a raspberry pi/arduino or something of the like along with GPS speed/heading so I can get a readout of my true wind VMG for speed testing without other boats around.So in other words, not very accurate at all, at the low end.
+/- .5ms = 20% inaccurate at 5kts and 10% at 10kts.
What is the problem that the ultrasonic is solving, over the standard anemometer with cups?
