BalticBandit
- 36
The plan is to wrap loosely around the inflatable tube offsetting the seams by 90 deg each layer. What I see this as allowing me to do is to eventually go to a female mold for oblong parts.The only issue I see with that plan is the fiber crimping (minor but research shows just 7 degrees of fiber crimp makes a significant impact on strength) If you wrap tight around the inflatable tube before going into the hard tube, you'd prolly be able to avoid that since the laminate would have to expand and the fiber crimps would get straightened out. this is why Hall spars exclusively use aluminum mandrels, when the part goes into the autoclave the aluminum expands with the heat and straightens any fiber crimps.
Another thought I had to experiment with was to use a discardable spacers to hold apart the wetted out layers and then fill them with self-expanding urethane foam as a way of getting the benefits of "inverted vaccum pressure" on foam core parts while mimimizing post cure sanding.
