Mylar film (from TAP Plastics et al) works well between the mandrel and the layup. You need to tape it in place initially, then remove the tape as you slip some biaxial braiding down it.Yes yes yes, a body of mine or I did that exact thing. If I remember, we ended up with a lot of the broken glass still glued to the wall. Not a bad low tech method if you properly wax/pva the bulb.wind_apparent said:Has anyone tried using floresent light tubes as mandrels? was thinking you could tape the tube with flashbreaker, lay up, cure, then blow up the bulb and pull the mess out.
You can also coat the mandrel with wax before wrapping with mylar for added piece of mind.
I've used this technique for carbon tiller extensions. The mandrel for those was delrin rod, also sourced from Tap Plastics. The carbon braided sleeving came from Soller Composites.
