I have a 20 year old Porter Cable 6" RO that is still going strong. No, it's not a vacuum one, but it's not $1K either to replace.1k$ on another sander
I have a $15 AUD Aldi variable speed angle grinder fitted with a 6" soft sanding pad.I have a 20 year old Porter Cable 6" RO that is still going strong. No, it's not a vacuum one, but it's not $1K either to replace.
If it works it works. It's not that I can't do it with that, it's that I own(ed) the exact bloody tool I wanted to do it with that allows me to get away with things like not masking off, not a problem in some places but here a definite issue, it's the perfect combination of speed/quality. So I'm pissed off. The downside to the tool lending and I'll get it back when I need it approach. Probably going to take the crochety old man approach to tool lending until I'm less cranky.I have a $15 AUD Aldi variable speed angle grinder fitted with a 6" soft sanding pad.
Bit brutal but I've got a steel boat.
If/when I kill the thing I'm out $15. I bought 5 of the things when they were on a clearance sale so - shrug.
FKT
Rule 1: I bring all the tools.
Rule 2: you can't borrow them. I'm happy to help, will work for beer.
I lucked out - I happened to run into Jani (sp?) one day and he was willing to loan it for a day or two: perfect timing!You can rent them.
As close as Ambleside.
Dynamic Equipment.Dunno the name - 15th & Clyde
And he's Jonni - pronounced Yonni
They always seem to use them as pry bars, bending the screw drivers and buggering the chisel tips. Worst part, they could have easily used the actual pry bar sitting right there in plain sight.That sign applies DOUBLE to wives/GF's who borrow good screw drivers, chisels etc only to use/lose/abuse them.
that's a big pet peeve. I always keep my old set of whatever hand tools around for loaners. I mistakenly thought that being crystal clear about the costs of specialty tools would mean they would be treated with the same respect I've given their tools when borrowed(return it complete, and cleaner than you got it). Lesson learned.They always seem to use them as pry bars, bending the screw drivers and buggering the chisel tips. Worst part, they could have easily used the actual pry bar sitting right there in plain sight.
