it's for sure a design issue. but it's my design issue now and I'm looking for a way to fix it.I'm going with design issue .
Calling it "Ray Charles' cut out." made me laugh out loud at dinner.... thanks for that. I'll look into an aluminum piece. It'll have to be a couple of them. I don't have access from underneath so it'll be tricky to affix. but i like that idea. It'd look clean.Definitely start with cleaning up Ray Charles’ cut out. You could bond a piece of 1/4” 6061 aluminum to the underside of the deck that matches the shape of the cut out (albeit slightly smaller than the Ray Charles’ cut job). The aluminum can be easily radiused and polished smooth, so the line would instead be rubbing against the rounded and polished aluminum radius, rather than ragged glass.
man i wish it were that easy. there's a 2nd cleat further in. the one you can see is just the secondary safety. So that one can't have a keeper on it or the other wouldn't be able to uncleat. you comment did make me wonder if anyone's ever tried putting clutches there though. That would be kind of cool. Just have the handle flush with the deck and pull it up in the gybe to blow the old one. Probably needlessly heavy and complicated though.You could put a keeper over the cam cleat and do whatever you want to make the deck look better
Rope constrictorman i wish it were that easy. there's a 2nd cleat further in. the one you can see is just the secondary safety. So that one can't have a keeper on it or the other wouldn't be able to uncleat. you comment did make me wonder if anyone's ever tried putting clutches there though. That would be kind of cool. Just have the handle flush with the deck and pull it up in the gybe to blow the old one. Probably needlessly heavy and complicated though.
