Jud - s/v Sputnik
I want to remove my key switch and change it to a push button start. The engine panel is low-ish, just to the side of where you access the nav table, at foot level, and I’m always paranoid that someone’s gonna kick or bump the key and break something. As well, the panel is just above the hatch to the ice chest, so it’s somewhat in the way when opening the hatch. I’m going to change the on-off toggle switch for panel lights to a push button as well - same reasons.
For the panel lights, I’ll use a standard Blue Sea on-off push button switch, part # 4162.
For the engine ignition, how do I do this? I’m not quite grasping this! My key switch has three positions, like most others, I assume : off - on (power to low oil pressure alarm/gauges) - momentary on to crank
Do I still need an on/off switch of some sort (button or rocker) for power to a momentary switch (for cranking)? (If so, then the trick is to choose a low-profile switch or button, and locate it on the instrument panel higher up, where it can’t be accidentally be kicked/bumped.)
