Panoramix
BTW, he installed a ground wire from the pod drive to the keel.
I think that it is a good start as long as one or the other (not both) is used as the common ground.
The ideal thing is to use a shielded cable for the three phase wires. If both sides of the shield were connected to the star point, then it wouldn't be a star point anymore. So I agree with you about that. I don't think it is a matter of getting back to earth (or sea) ground. I think it is a matter of providing as low an impedance conductive return path for the rapid dV/dt phase wires as possible.I've learnt the hard way the effects of ground loops by doing exactly what you are describing (star ground with interconnected nodes) while putting together a ham radio station. Did not make sense to me until somebody told me "your ground system is a big antenna whereas it should be a stable reference"
IMHO for best RF behaviour and to provide a direct return you can link directly the ground of the motor controller to the motor's but only one side should go to the common ground point which does not have to be the battery. TBH something in electrical contact with seawater is probably a good bet as the ocean is a pretty good ground if not the best ground you can find on earth!
Most boat builders probably don't bother but a diesel engine is surely less onerous in terms of EMI.
Just my point of view, at least that is the first fix I would try... immediately after isolating the motor AC controller from the rest with ferrite on its power supply.
You can try disconnecting it at the drive side to see if it makes any difference. But probably ferrites first!@Panoramix & @mckenzie.keith You are many levels above me. I will pass this on to the electrician who is helping me. BTW, he installed a ground wire from the pod drive to the keel.
Exactement !I'm a dummy on things electrical, so you mean the cables from the battery to the controller, n'est-ce pas?
Exactement !
Install the ferrite beads as close as practical to the controller.
From your experiment of dipping the transducer into the water, the more I think about it, the more I suspect that the transducer wire or the transducer itself is not properly shielded and picking up EMI from the motor. If there is an easy way to ground its shield (assuming there is one!), it is worth a try. I think that if the plotter was affected by a badly filtered controller sending back into its power supply parasitic AC (what the ferrite beads are trying to solve), dipping the transducer in the water would not have solved the issue. If I am right on this, shielding the motor wires should help also.
It is not easy to solve without poking around, your best bet is somebody who knows about RF. I own an electric car and I know that it is electrically noisy so I think that your boat is likely to be noisy hence the need to shield cables which carry data.
What is the acoustic refractive index of toilet wax? 😜Seems like the signal could be greatly attenuated from quartz to wax to laminate (to mussels) to water and back again.@J_Grove , @mckenzie.keith , @Panoramix , I got some more info today:
1) I put ferrite beads on the power supply cables (Battery -> Pod Controller) - no luck. I added one to the transducer data cable, next to the device, and another on the same cable where it passes near the cables which supply power to the pod - no luck. It was a beautiful day, sunny 75º, NE wind about 8 knots, so I went sailing.
2) While sailing the depth readings were fine until I hit deeper water. Then I would loose the signal. This would happen when I got to water 40+ or 50+ feet. The signal would then be off for most of the time I was in the deeper water, about 90%+ of the time. I might get a brief reading. As I approached shallower water, say mid-30 feet, the signal would return. Boat speed didn't matter.
All of this, plus the dipping of the transducer, suggests to me and the electrician that the problem is not EMI, it's that the transom-mount transponder sitting in a glob of toilet seal wax is just not cutting it.
I'm going to talk to Garmin. In the meantime, I would welcome comments.
If you earlier observation that starting the motor interfere with the readings still stand, it is probably a mix then... Signal is very weak and I imagine that when you switch on the motor the weak signal gets drowned by the EMI.All of this, plus the dipping of the transducer, suggests to me and the electrician that the problem is not EMI, it's that the transom-mount transponder sitting in a glob of toilet seal wax is just not cutting it.
I ran this whole thing by my ePropulsion dealer, who is an electrical engineer, and haven't heard back yet. I also want to talk to Garmin. I'm thinking I might try the real Garmin in-hull transducer, but if it doesn't work, I would want to return it.If you earlier observation that starting the motor interfere with the readings still stand, it is probably a mix then... Signal is very weak and I imagine that when you switch on the motor the weak signal gets drowned by the EMI.
Not sure how easy it is but shielding the motor-controller cables would help with suppressing the motor interferences. If not too difficult I would be tempted to do it just too limit the risk of further issues.
Switching transducer will probably fix the issue...
Hi Bull City - I'm just curious if you tried that test that I suggested in your original thread yet.I ran this whole thing by my ePropulsion dealer, who is an electrical engineer, and haven't heard back yet. I also want to talk to Garmin. I'm thinking I might try the real Garmin in-hull transducer, but if it doesn't work, I would want to return it.
Yes it seems like that should work acoustically. You could also set it in bilge water possibly.@S35 You mean:
If you can, create a ring with that wax that's an appropriate diameter for the transducer. Make sure that the walls of the ring are about 1-1.5 inches high. Once in place, fill it with water and then put the transducer in the center?
No, I have not, but I may do it before committing to another transducer.
Yep - That's the one.@S35 You mean:
