Sail4beer
Usual suspect
Resale shop of Texas is on par with that type of chandlery.
GeeFalmouth has an impressive skyline
If I needed some yard work. What’s the best place in the Caribbean to get it?
Add some hand-holds. Re-bed some things I don’t have the confidence for. I did the chain plate, but these port lights with the sex bolts….fridge work. Maybe a furler for the staysailGee
Right in Falmouth is a sophisticated marine industry
And you must identify what “ yard work “. Means
Typically you do big jobs in St Martin
The skyline is impressive. It's ok to be different than everyone else.One of these doesn’t look like the others…thanks @Russell Brown for giving me the coolest ride.
I have debated long and hard about adding a furler on my staysail. I currently have it on very robust hanks and I think I prefer that. It is foolproof, plus my staysail has the option to reef it to a stormsail, although the conditions that would require that would be pretty rough. And of course if it was on a furler I could partially furl it from the cockpit. I even have a spare staysail ready to go on a furler, and in Fiji acquired another used ProFurl identical to the one my jib is on. But still vaccillating on setting it up.Add some hand-holds. Re-bed some things I don’t have the confidence for. I did the chain plate, but these port lights with the sex bolts….fridge work. Maybe a furler for the staysail
Good = quality of work, not super yacht prices, but not cheep.
Hank on has much lower windage than a rolled staysailI have debated long and hard about adding a furler on my staysail. I currently have it on very robust hanks and I think I prefer that. It is foolproof, plus my staysail has the option to reef it to a stormsail, although the conditions that would require that would be pretty rough. And of course if it was on a furler I could partially furl it from the cockpit. I even have a spare staysail ready to go on a furler, and in Fiji acquired another used ProFurl identical to the one my jib is on. But still vaccillating on setting it up.
I rebedded my port lights on my Wauquiez. I believe you have the same ports. It was pretty easy to do. My only problem was, for a couple of the "sex-bolts", salt water corrosion of the aluminum "sex-bolts". For replacing them, I had to find some in Mexico. Which was painful. Turns out they had them and were used for securing bathroom stalls. They do have the safety head on them so removing them will be ugly but...Add some hand-holds. Re-bed some things I don’t have the confidence for. I did the chain plate, but these port lights with the sex bolts….fridge work. Maybe a furler for the staysail
I have lots of butyl tapeI rebedded my port lights on my Wauquiez. I believe you have the same ports. It was pretty easy to do. My only problem was, for a couple of the "sex-bolts", salt water corrosion of the aluminum "sex-bolts". For replacing them, I had to find some in Mexico. Which was painful. Turns out they had them and were used for securing bathroom stalls. They do have the safety head on them so removing them will be ugly but...
I used butyl tape to seal against water BTW. Hasn't leaked it years and we have done some serious ocean miles with them.
Mine are built into the liner. I’m looking to add a stripper pole or two. We’re short and Ted was tall.As to handholds in the cabin, I wonder if your ceiling is like mine? Do you have the drop down panels that run the length of the cabin with plastic battens in-between? That is how mine are. They are held up with small screws. On my boat, you can see when the ceiling panel is removed, Wauquiez fiberglassed these standoff beams that the panels screw to. I bought teak handrails and thru-bolted them to these beams on either side of the main hatch. I can do pullups on them.
Of course, my 6'3" kid can hit his head on these. When they were younger, these handrails became monkeybars for them!
Here they are varnished.
Here you can see the beams Wauquiez glassed in. I just screwed the handrails right into them. Very solid.
I’ve just set up my staysail (which is hanked on so that it’s raise-able from the cockpit). My set up:Hank on has much lower windage than a rolled staysail
This is significant at anchor and when docking
No, thank you for the coolest photo!One of these doesn’t look like the others…thanks @Russell Brown for giving me the coolest ride.
A bull rail! Oh the horror!!!One of these doesn’t look like the others…thanks @Russell Brown for giving me the coolest ride.
Jud, have you sailed much with it? I bag mine when at anchor, just as I cover the mainsail. But when sailing I almost always have the staysail set, no matter the angle of sail or the conditions, so before raising anchor or leaving a mooring or slip I simply open the bag just as I would uncover the main, so no need to go forward if conditions worsen and you need to furl the jib and use the staysail, it is ready, and in my case already raised and working. I would however need to go forward to attach the second set of sheets at the reef point if I ever needed it as a stormsail, and that would not be fun, so the furler option is appealing if I think I will ever need that option. So far I have not.I’ve just set up my staysail (which is hanked on so that it’s raise-able from the cockpit). My set up:
-staysail bagged and hanked on stay; bag lashed to a stout stainless steel rail that is on the centreline of the foredeck
-my jacklines run on the centreline of the boat; I have a Dyneema workstation tether at a strong point at the staysail stay (inner foresray)
-staysail halyards runs aft to cockpit
Raising staysail does require going forward briefly, just to unbag (pull lashings and bag off), then return to cockpit). Halyard in clutch in cockpit. Sort of a hybrid between a furler and having to raise the sail at the mast (which I wanted to avoid).
If you find someone to do the work, North Sound Marina in Antigua is the nicest yard. Massive concrete work area with bullet proof tie-downs and a fair amount of covered space. But the labor pool can be hit and miss. Fujin was rebuilt there after the 2018 capsize and came back better than ever. But we had skilled management on site most of the time and found our own skilled labor. Falmouth is attractive and usually full of a spectacular assortment of sailboats. But I don't know much about the boat yards.Falmouth has an impressive skyline
I've spent 2.5 of the last 3 years in the Caribbean, and have done a lot of boat projects. Sint Maarten is the place to go for granular technical work or work that needs a lot of parts. I recently paid $60-$90/hr for very skilled and efficient workers during a rig survey and refit. Machining custom parts was $95, welding was $85. FKG is far and away the best rigger in the Caribbean. Tradesmen in Sint Maarten are used to the demands of the megayachts, it's quite competitive, and in my experience they are quick and careful. Getting parts is easy, Fedex in 2 days, no screwing around with duties blah blah. The chandleries are well stocked as are the main service providers, and many, not all, parts prices are similar to the US. The haulout yards are dirty and dusty, but in Cole Bay super convenient to parts and services.Add some hand-holds. Re-bed some things I don’t have the confidence for. I did the chain plate, but these port lights with the sex bolts….fridge work. Maybe a furler for the staysail
