Chasing Elegua
2airishuman
The Loyal Opposition
1,012
487
Minneapolis area
I personally just like short tacking up narrow channels and onto anchor too much to be happy with a fixed furler. But most people simply turn their engines on, and I get it.
I am not a cutter guy but I have really enjoyed some of my narrow channel trips and would not want to give up that ability in a boat.
Zonker
7,032
Canada
That might or might not be rigid enough for the job.
I'd say "Not". Spartite just isn't that rigid.
I agree that the side plates are too thin and are probably flexing. Much prefer the chunky aluminum anodized one further up.
my gut instinct would be to pour in place a toughened G-Flex plug
No. G-flex is about (very roughly) as rigid as Spartite. Both are flexy when cured
It's odd that even big, expensive expedition-oriented cruising boats still mostly require their crew to work outside.
Yes. Stand watch inside a nice dozy pilothouse with the heater on. Need to adjust sails - OK step out and do so, then dash back inside where it is warm. Seldom do you NEED to be out in the weather.
Elegua
Generalissimo
Ok, that was weird. Heard some splashing like someone swimming outside the boat. So I go out and look and it’s a manta the size of my dinghy tangled in the slimeline. Took some time and with a bit of trepidation to untangle it. Yes, they are harmless, but it was big and I had to hold on to the horn to get the line off. Only ever seen one from afar while diving.
Security guy wanted to eat it. BBQ stingray is tasty (a Singapore specialty) but not large manta!
Max Rockatansky
DILLIGAF?
4,030
1,102
What’s a slimeline?
Scuff
14
USA
On your vang bracket .. garhauer should be able to make you one if you send them a template. I had a solent fitting made by them. If rig rite doesn't have it in stock don't hold your breath. I ordered an isomat step and had to cancel it after waiting 6 months.
slug zitski
Banned
7,495
1,612
worldwide
The shoreline from the mooring block when doing a stern-in med-moor. You pick it up off the dock and move it to your bow roller and haul in. It saves you the hassle of dropping anchor and is hopefully more secure. It spends most of it’s time in the water so it gets a bit slimy hence the name..
Often referred to as the “dead man “
accnick
2,794
In my world, a deadman is a heavy anchor point ashore that is used to secure the fixed end of a cable or purchase, typically used as part of the hauling system for a marine railway. In its simplest form, the cable goes from the drum on the hauling winch, through a traveling block (which may be configured as a snatch block) on a moving sled or on the railway cradle, to the shackle on the deadman.
There's even one on the hauling ramp in out boatyard.
It's something solid, that ain't gonna move, that you can attach things to, usually to help move heavy things.
Ajax
3,285
Edgewater, MD
Ok, so he's doing a Med moor?
My understanding is that there's no finger dock in between you and your neighbors. How close to people tie up to you in this arrangement? I assume you put out lots of fenders. Is hull contact common in this situation?
slug zitski
Banned
7,495
1,612
worldwide
Yes
plenty of fenders on your leeward side …you then back in , lay on the boat next to you , throw a stern line, pick up the ground line then set yourself in the berth
very difficult is you have no boat to lay against ..very difficult if there is no marinero to catch your stern line and pass the mooring tail
typically, when short handed , it’s easiest to anchor then go stern too…in many ports anchoring is not possible
Ajax
3,285
Edgewater, MD
Yes, I can see the difficulty if there's no boat and you're taking a breeze on your broadside.
The slimeline is interesting, I thought that the bow mooring would be a float in the water that you'd grab, not something laying on the pier that you'd walk up to your bow.
slug zitski
Banned
7,495
1,612
worldwide
You would back over it and foul your prop , then you must add a pennat long enough to allow the boat to get to the dock
in addition picking up a spar bouy is a challenge
the mooring tail is rather messy but easy
at high class marinas like Puerto Cuervo a marinero in a rib picks up the tail and passes it to your bow crew
Elegua
Generalissimo
Ribs, bow crew, bow thrusters. All super yacht stuff.
The wind is up, so I’m not super excited about getting off the dock as I planned this afternoon. The potential for things to go spectacularly wrong is big. Discretion something, something valor.
Oh, yeah; spray some raid on you dock lines to avoid boarders.
slug zitski
Banned
7,495
1,612
worldwide
You time your arrival and departure acording to the thermal, sea breeze
sometimes at dawn, sometimes at dusk
some of the berths in English harbour are very difficult
soon you will learn the “ good spots “
the reason why god made tips is that you get to ask for a specific , good spot ..berth
when the wind is light everyone is a seasoned pro…
Elegua
Generalissimo
Yeah, before 11am or after 3pm. Then I can play at seasoned pro.
