• The Forum will be unavailable on March 27, 2023 from 8:AM to 12:00 PM EST for maintenance.
Chasing Elegua
Jud - s/v Sputnik
1,997
Canada
A floating ring system will achieve the same result - but be aware that anytime the sheet is loose, that ring WILL be flogging about
These systems mostly used with an 'inhauler' and/or an 'outhauler' to pull the lead inboard/outboard. And in most pictures of these systems in use you will see some stout bungee holding the ring up
And there is a fair bit of friction with those rings, they are mostly used with bare spectra lines
Thanks - looking at a pic (from last summer when winds built and built and I was a bit too chicken and/or lazy [“we’ll be in before too long; besides how much more can it increase?”] to put a reef in the main, so I just kept reefing the Genoa, and quickly began wishing for better sheet lead control), I don’t see how I could ever control a floating ring to keep it from flogging around when the sheet is loose. Seems like a traditional adjustable car system would be better.
Elegua
Generalissimo
For older masthead sloops like mine, where the mainsail is higher aspect, I found reefing the mainsail first works better, especially if you need to drive upwind into a sea. That’s why I really needed the adjustable cars. Once you’ve reefed the main as the wind builds you keep reefing the genoa until you don’t want to beat on it anymore, then you raise the staysail. I need over 20kts true to have the staysail work efficiently. My first mainsail reef is about 16% luff reduction, so closer to a double reef.
Jud - s/v Sputnik
1,997
Canada
Thanks. Pretty much describes my set up too (high aspect main, two deep reefs, but I haven’t really had the chance to use the staysail much in higher winds.) More reefing practice needed…and much more free time to go sailing needed :) Soon…soon… (Going to Andalusia, Spain soon on a trip and lately I’m guiltily wishing I could go off sailing instead… :) )
estarzinger
1,141
As an aside, usually, when we wanted to move the cars forward we also wanted to move them a bit outboard, so we usually used blocks on the toerail rather than actually moving the cars on the track.
For a cruising boat, I personally would rate easy-to-adjust blocks (with ball bearings and 4:1 tackle) a 'nice to have' rather than higher than that. I do think Elegua is not yet in 'gentleman mode' and still sailing to windward when there might be other options :)
Elegua
Generalissimo
Like a rental car?
I’ve discovered there is a reward for being ungentlemanly - an empty anchorage. If I were smart, or if my wife were here, I’d wait for better conditions. But, this is still all new and exciting, so beating into the trades is still fun. For now. I might not go around the top of Guadeloupe- there seem few harbors outside of places like La Desirade which don’t really have an anchorage.
The snatch blocks on the toe rail are my after guys - to pole out the asymmetric to windward for a little
more soaking, get a better sheet angle for wing-on-wing and they also do double duty as poor-man’s 3d sheet for reaching and running. I borrowed this idea from Jon Eisberg (sp?). I didn’t have a good solution for upwind, so I got the genoa leads.
Here we are being lazy slackers on the ICW - No mainsail.
longy
Overlord of Anarchy
7,192
1,388
San Diego
The herd cannot/will not go upwind. So the ability to sail the hard way will reap many rewards. Anything/everything/everybody goes downwind. So do 90% or more of the cruising fleet
estarzinger
1,141
Luckily it was calm. Just took patience and some help from neighbors.
I Ireland we once pulled up a 300lb ancient Spanish fisherman-style anchor. The local historian said it might have been from one of the various invasion fleets. It is sitting in a museum now. Probably easier to deal with than a tree because while heavy it was not too hard to get a spin halyard on it and shift it off the Bruce anchor.
toddster
1,144
The Gorge
Just out of paranoia, I've been setting an anchor buoy on an Amsteel line in some of these old logging-area anchorages I've been frequenting. Haven't "caught" anything yet though.
Elegua
Generalissimo
Now that’s a cool find.
The hard part about the tree was getting the chain untangled from the root-ball. Also had to saw off a couple limbs. Fortunately it weighed a lot less than 300#.
sculpin
I caught a submerged cable one time (un-used, un-marked), about 2" diameter. Holding was great. Pulled it up, luckily it came to water level. I worked a rope around it and tied that off, then lowered the anchor and got it free. Cut the rope, away we went.
Kolibri
625
Haleiwa, HI
A friend of mine was recently anchored just inside the breakwater in Haleiwa Harbor. He found a shopping cart attached to his anchor when he pulled it up.
