dreamingwet
- 107
there are quite a few C40's with Raymarine's linear drive, either as a backup or as main, BUT I had 3 of them fail so I am not sure about their reliability.
What’s the state of the art in reasonably priced autopilots?
Criteria:
Reasonable price.
Lowish electrical consumption.
Reliable.
Plays well with B&G 5000, but not really expected to sail well to AWA or TWA unless that can be done while fulfilling the above points.
Basically, what are all the unsponsored short-handed racers in medium size boats using for the Round Britain, Fastnet, Mini-Transat, etc?
Thanks
I put this on my O' Day 39. KISS, very happy http://cptautopilot.com/What’s the state of the art in reasonably priced autopilots?
Criteria:
Reasonable price.
Reliable.
Thanks
Those were really challenging conditions those last couple days with that south swell, but interesting that the pelagic was correcting better."BobJ, did you have to spend a lot of time learning to tweak yours to use in the Pac Cup?"
Yes, and that's a trade-off when using these higher-end pilots for non-pro racing, where you're not able to keep tweaking them. There are times when I miss the plug-and-play simplicity of the Raymarine gear I had on the J/92.
I had the B&G pilot dialed in pretty well for local racing but it couldn't keep up with the sea state in the second half of the PacCup. TS Darby (racing over) and then TS Frank (coming back) complicated the wave patterns and made it tough to rely on the autopilot. The Pelagic steered more reliably than the B&G pilot when the sea state was bad.
Permit me to chime in please…
I’ve had, and used, many types of pilots.. ranging from 30 footers to mega yacht.
Here’s what I agree with…
The NKE hydraulic drive is more robust than the raymarine linear drive. The raymarine uses plastic gears in a cyclocyclic planetary drive.
But, it’s a fraction of the NKE cost.
Raymarine also makes a hydraulic unit, but it’s not as robust, it responsive as the NKE.
I favour the raymarine EV corepack and displays . I have found that their new evolution steers like the boat is on tracks, and the interface is excellent.
But, I haven’t steered in wind mode in huge ocean swells.
I know that in North America, your best service option is raymarine & B&G.
For a wheel steered boat, your best option is a Lewmar Mamba (Whitlock) motor attached directly to the steering gearing. Very robust. Jeffa makes this as well, but Lewmar’s market is much bigger.
I have a top end Raymarine system, and it’s less than 1/2 the cost of NKE.
And, the huge problem is mixing gear.
I guarantee you (based on years of frustration), that you get sun-optimal results when using multiple vendors on a system. They all tweek their gear to use with their own periphials.
B&G support in Canada is lacking, so I’ll be staying with RM for the expected future
Second vote for the Pelagic.Pelagics are great but they can fail too. So what is your back up autohelm system?
Given a choice do you want to hand steer for a week or more by yourself as a few have in trans ocean races and returns or spend 500 dollars to insure you do not have to?
First off, I would not take Foolish's advise lightly, this guy literally wrote the book on single handing (and its a very good book if you have not had the the pleasure of reading it).It all depends on your boat, and I can tell you that a boat for the Mini Transat will have COMPLETELY different requirements than a stable cruiser used in the Round Britain. I sail an Olson 30, which is an ultralight and very twitchy boat. After extensive testing I can tell you that the Pelagic is completely unsuitable downwind in anything more than 15 knots. Even the Raymarine will only take me to 20 knots downwind in flatish water. A Mini would have worse results with either of these. However, if you sail a very stable boat, then either would do just fine in most conditions. I will give you one strong piece of advice: DO NOT MIX SYSTEMS. If you mix systems, then you will have extreme difficulty getting them to work and you will be absolutely unable to get support. Each manufacturer will blame the other system. Every manufacturer tells you that their system works with all others, but don't believe it. I am living proof, after 20 years of trying, that you can't mix systems. One final piece of advice, stay away from Actisense at all costs. I found the guys to be complete jerks who would not help me out at all.
Unless you compare it to the b&g... no base station required, small, light, you can pre program your auto tack in degrees to the wind angle. And, it's Half the price...Another consideration for an autopilot is the availability of a low cost remote control, especially when sailing short- or single-handed. Raymarine is the clear winner in that regard.
The Navico/B&G remote is $169Another consideration for an autopilot is the availability of a low cost remote control, especially when sailing short- or single-handed. Raymarine is the clear winner in that regard.
Yes indeedYou might also consider the Jefa linear drive
I've installed 4 of these - very un-impressed with performanceAnother consideration for an autopilot is the availability of a low cost remote control, especially when sailing short- or single-handed. Raymarine is the clear winner in that regard.
