Max Rockatansky
DILLIGAF?
- 4,030
- 1,102
I looked it up but would have preferred a direct link...look up the inverted method, that will let you get as long of a steep as you want. I do long steep times when using a coarser grind (which saves a bit of grinding effort when I’m using a manual burr grinder).
Upside Down Brewing Results in a Richer Taste
When you brew inverted, all the coffee grounds will make contact with the water the entire brewing period. This is called full or total immersion. Full immersion brewing methods are known for having a richer taste than brewing methods where the coffee begins passing through the filter immediately. The most popular full immersion brewing method being the French Press.
This isn’t the first time you’ve whined about not being provided a link. If someone takes the time to direct you to a research subject, then it’s not his job to do the research for you. Your Google aint broke, get off your ass and search.I looked it up but would have preferred a direct link...
I did this search and am not sure which 'get off your ass' is worse...This isn’t the first time you’ve whined about not being provided a link. If someone takes the time to direct you to a research subject, then it’s not his job to do the research for you. Your Google aint broke, get off your ass and search.
Fuck you. Saying "Look it up" instead of providing a link is lazy. Having a bad day?This isn’t the first time you’ve whined about not being provided a link. If someone takes the time to direct you to a research subject, then it’s not his job to do the research for you. Your Google aint broke, get off your ass and search.
Thanks for the FU.Saying "Look it up" instead of providing a link is lazy.
Unless you and @Max Rockatansky are the same person, the wires got crossed on this one. The FU was directed at him, who responded very ungraciously to my reply to you.Have a nice Sunday.
Anyone figured out how to secure the biatletti when rocking and rolling? Too small for the standard pot holders on the Dickenson... I was thinking maybe an aluminum ring, like a piece of pipe, but that seems overkill and will create a random piece of hot metal... Not a good solution so won't do it...
I do not have a Dickenson, however just looked at the relevant pot holder pics. I would cannibalize a pot holder, or some other stainless galley ware to make a taller pot holder of some sort. Use your TIG welder... On that note, the wife's kitchen drawers are a great source of stainless bits for projects. Be sure to hide the evidence.Anyone figured out how to secure the biatletti when rocking and rolling? Too small for the standard pot holders on the Dickenson... I was thinking maybe an aluminum ring, like a piece of pipe, but that seems overkill and will create a random piece of hot metal... Not a good solution so won't do it...
Get a bigger one like the 12 cup - that should fit.Anyone figured out how to secure the biatletti when rocking and rolling? Too small for the standard pot holders on the Dickenson... I was thinking maybe an aluminum ring, like a piece of pipe, but that seems overkill and will create a random piece of hot metal... Not a good solution so won't do it...
You don't explain what part the screwdriver or the clams plays in the coffee making process.Tea kettle , funnel and paper filters makes a fine cup of coffee ...and zero clean up mess
The Bialetti's center of gravity is so low I wouldn't think it would take much. Maybe 3 small cable clamps around one burner? Simple wire ring with a couple legs? On a gimbled stove, I'd say a Bialetti is good to force 8.Anyone figured out how to secure the biatletti when rocking and rolling? Too small for the standard pot holders on the Dickenson... I was thinking maybe an aluminum ring, like a piece of pipe, but that seems overkill and will create a random piece of hot metal... Not a good solution so won't do it...
can't offer any help - i sail a multihull...Anyone figured out how to secure the biatletti when rocking and rolling? Too small for the standard pot holders on the Dickenson... I was thinking maybe an aluminum ring, like a piece of pipe, but that seems overkill and will create a random piece of hot metal... Not a good solution so won't do it...
Wow I just saw this. I will try it out this weekend. (I had no trouble with a google search.) I never knew about "the bloom" before. Regardless, coffee while camping or on the boat tastes better that at home, no matter how you brew it.@Mizzmo: look up the inverted method, that will let you get as long of a steep as you want. I do long steep times when using a coarser grind (which saves a bit of grinding effort when I’m using a manual burr grinder).
