IStream
- 3,292
The general answer to your question depends heavily on whether you wire the 100W panels in series or in parallel. Separate controllers will get you higher overall output compared to series-wired panels if one panel is shaded. However, parallel wiring the panels inherently prevents the shading of one panel from drastically affecting the output of the other, so I doubt you'd gain much overall output in a shading scenario with separate controllers versus parallel-wired panels.Sorry - I didn’t really word things well. Typing on a phone on the fly.
What I’m wondering is, if I paralleled the two 100w panels and put them on their own controller together, and then put the proposed/possible future 50w one on its own controller, would the total output be any different than if I did not parallel the two 100w panels and instead left them each one their own controller (with the 50w on also on its own controller). Is there an appreciable output difference between the two wiring/panel set up scenarios?
Since you'd plan to wire them in parallel, I don't think a fourth controller will get you much more than redundancy. If you value that, I'd suggest getting four controllers and size all your controllers such that they can handle 200W (with appropriate voltage limits). With that, any one of them can shit the bed and you'll still be able to go to a 200W + 2x100W (2P1S) + 50W config. If two of them shit the bed, you'd still have 400W available in a 200W + 2x100W (2P1S) config with the 50W panel disconnected.
