Yah…tough jobworst part is going to be trying to polish them up with out being able to get inthe corners near the wood.
Lexan is polycarbonate and scratches very easily. Acrylic does not scratch as easily and is what most professional shops recommend.I would go with Lexan.
I am certainly not a material scientist or necessarily update to date with what is best and fancy for modern/expensive boats, but lexan has been around for a while. It does require things like the wife/girlfriend not cleaning it with 'windex' from the house but it is solid. Your wood frames will probably cave in before the windows. And stay crystal clear.
I'm gonna try out what this dude did on his headlights on my companionway board. It's a solid piece of plastic with some teak strengtheners bolted across it.. has about the same transparency as yours does.... this couldn't possible make it any worse than it is right now....Do I try to polish these or replace them? This companionway will face south and so I’d like them to be UV resistant while still letting in a lot of light. Lexan? The woodwork to replace them is not a concern.
Note: I am living aboard and would like a view. Not interested in solid or dark options.
View attachment 566883 View attachment 566885
I would recommend reading the article posted by yoyo. You can get in trouble doing a drop-in replacement of a polycarbonate ("Lexan") panel in a hatch that was designed for acrylic. Flex characteristics of the two materials are different, and you can pop the panel out of its frame. Which is unlikely to happen in your harbor at noon on a warm, calm, sunny day.I would go with Lexan.
Hinged doors work on some boats but can be hard to live withI'd use surface hardened polycarbonate if replacing those. It will outlast acrylic.
But if I was living aboard like you are, I'd bin those immediately and replace with swinging companionway doors. Drop boards are an extreme PITA if you spend a lot of time aboard. I don't know what the rest of your companionway looks like, but it is often possible to keep the drop board channels and mount removable swinging door inside of them. Then if you really feel the need (for security or weather) you can remove the swinging and install the drop. Thats how I designed mine.
