MultiThom
Ronstan has this textile rope clutch that just came out. Wondering if it works better than a spinlock. They don't call it a cleat, but...https://www.ronstan.us/marine5/range.asp?RnID=422
I'm not very familiar with trimaran rigging so take my opinion with a grain of salt. But, as you lock down the constrictor clutch it moves back a centimeter or so before the sleeve constricts and grabs the line. If you need a very specific load and tension such as on a shroud it might not work.I wonder if it could be used in place of a hifield lever on a trimaran shroud. To fold/unfold many folding trimarans, the shrouds have to be loosened then tightened. Usually with a hifield lever or a series of cascading small diameter lines. while sailing, the shrouds are loose, tight, loose, tight as tacks are changed; so normally folks don't rely on cleats and I wonder if this device would hold...might simplify some rigging.
I tried the XTX, in my experience and situation I went back to the Ronstan/Cousin constrictor. XTX was covered here:Kinda thought the OP was looking for a view on the Ronstan/Cousin-Trestec versus the Spinlock XTX Soft Grip. For those without enough lineal length for the Ronstans, what about the XTX?
Actually, I'm looking for a method of shortening a dyneema shroud (holds the mast up). For some folding trimarans (like mine), you have to first loosen the shroud (something else is holding the mast up), then push out the float, then tighten the shroud for sailing; then go do the other float. A metal hifield lever was used on some boats with wire shrouds. What most use now (as do I) is a cascade of smaller diameter dyneema so the shroud can be loosened and tightened with the thin lines knotted off securely. This works, but is time consuming. The shrouds are alternately loosened and tightened while sailing (Leeward shroud is always loose). I'll probably stick with the cascade since it is reliable and nobody wants to get dismasted; but always looking for something to make my sailing more enjoyable.Kinda thought the OP was looking for a view on the Ronstan/Cousin-Trestec versus the Spinlock XTX Soft Grip. For those without enough lineal length for the Ronstans, what about the XTX?
I use a cascade of blocks and constrictor clutches for a 8mm line. If the clutch fails the blocks of the cascade stop them to get any further. After three seasons no problem.Actually, I'm looking for a method of shortening a dyneema shroud (holds the mast up). For some folding trimarans (like mine), you have to first loosen the shroud (something else is holding the mast up), then push out the float, then tighten the shroud for sailing; then go do the other float. A metal hifield lever was used on some boats with wire shrouds. What most use now (as do I) is a cascade of smaller diameter dyneema so the shroud can be loosened and tightened with the thin lines knotted off securely. This works, but is time consuming. The shrouds are alternately loosened and tightened while sailing (Leeward shroud is always loose). I'll probably stick with the cascade since it is reliable and nobody wants to get dismasted; but always looking for something to make my sailing more enjoyable.
I had tried a whoopie sling in this application instead of the cascade; but I found that I needed slack in the shroud in order to release the sling--which prompted my enquiry about these constrictors since it seems to be the same principle but with a built in method of releasing while loaded.
