That boat can't possibly still be floating.What a f**king death trap! And did you hear the douche bag narrator explain it away? It was done because of the galley. What is the world coming to?
that galley will only produce one meal!What a f**king death trap! And did you hear the douche bag narrator explain it away? It was done because of the galley. What is the world coming to?
As long as its French Toast, does it really matter?that galley will only produce one meal!
Why does he give a fuck where the boat is going? When you're sailing a boat that expensive, everybody gets out of your way. Lighthouses get out of your way.Even if the bongo board was tacked, yer man still has almost no view of where the boat is goingI think the helm bongo board is out of tune?![]()
Perhaps he's a Sidehill Gouger, descended of the Highland clan Dunhu, who have one leg longer than the other and hunt mostly the wild haggis.No, it's supposed to bring you closer to level, not further out of whack. Someone set that one wrong.
Edit: I see what you're saying, but they are usually locked into place so you can stand anywhere on it.
It seems off because the cunningham appears to be absent in your picture as wellA floating tack is common design/construction for many one design classes - set the halyard to max hoist (black band), then adjust the other two corners as conditions dictate. There's a slug that holds the tack to the mast, but luff tension and sail shape gets controlled by cunningham, outhaul, sheet, and vang. The system allows for easier and more adjustment to sail shape. Might not be the best setup for offshore use!
The photo was taken before the start sequence began so the halyard's max'd but sail tensions haven't been set yet. Also, the sail in the pic's an old North we use for club races, the tack config look kinda strange with the bolt rope foot. Makes more sense with the loose foots on newer mainsails.
Cheers!
True, dat.Why does he give a fuck where the boat is going? When you're sailing a boat that expensive, everybody gets out of your way. Lighthouses get out of your way.
Actually, no... The cunningham's a single part line that runs down the starboard side of the mast then back to the cockpit. If you look closely you'll see the hook engaged in the cunningham cringle.It seems off because the cunningham appears to be absent in your picture as well![]()
Good job none of his mates were there to laugh at him.
Some of you may have been too lazy or busy to peruse Diarmuid's link to the wild haggis. Herewith, the wild haggis. It is worth reading.Perhaps he's a Sidehill Gouger, descended of the Highland clan Dunhu, who have one leg longer than the other and hunt mostly the wild haggis.
I guess the purpose of a tiller is to eliminate a wheel - definitely a good thing. lol. But the purpose of a swing up tiller is to clear the cockpit, obviously unnecessary over an aft deck.Fleetwood said:Both. A bit violent-looking for my taste, and tillers must swing up out of the way.
Actually, the other purpose of a swing-up tiller is to allow it to be held at a comfortable height when the helmswoman is standing, for example during pre-start maneouvres or when docking. Ideally, there will be just enough friction in the hinge to keep the tiller at the chosen height, but allow it to be easily raised or lowered.I guess the purpose of a tiller is to eliminate a wheel - definitely a good thing. lol. But the purpose of a swing up tiller is to clear the cockpit, obviously unnecessary over an aft deck.
of course, like when tacking the boat solo, where does it go then?Actually, the other purpose of a swing-up tiller is to allow it to be held at a comfortable height when the helmswoman is standing, for example during pre-start maneouvres or when docking. Ideally, there will be just enough friction in the hinge to keep the tiller at the chosen height, but allow it to be easily raised or lowered.
Yes, you can stand and hold the extension. But in many situations it is much easier and more effective to be able to hold the tiller itself.
If the rudder head is big enough to allow big cheeks on the tiller attachment, then it's quite easy to set it up so that it is both stiff enough for use without play, and also free enough to lift. The J/24 rudder head allows this to work wellof course, like when tacking the boat solo, where does it go then?
but the conflicting requirements of stiffness - plus mobility - necessary to hold the tiller in any particular position is a source of weakness as well. at least this is what I have found. iow, I totally get the advantages of having a fixed tiller over an aft deck.
