Megabyte in Florida
https://www.facebook.com/marketplace/item/319488200303914/
Probably an ex-DN sailor trying to replicate the setup!I expect to see this new development, the loose-luffed main, to rapidly spread to new fleets
The first dot point im sure is easier said than done hahahaPretty boat, only needs...
I'm missing some things, but that's a lot of it. Pretty boat. Race it Portsmouth as is and beg for the rating to be massively adjusted.
- Spinnaker launch tube
- Double spin poles and that expensive block that holds the inboard end
- Double sheet/guy blocks and all accompanying rigging
- Spin twing sheets, blocks, etc.
- Spinnaker is larger these days, probably need all new sails anyway
- New centerboard
- New rudder
- New rudder transom support beam to handle new loads of rudder
- Mast ram and all accompanying rigging
- 16:1 vang
- 32:1 shrouds and all accompanying rigging
- Mainsail clew reefing system
- Every block not already replaced and many lines, replaced with blocks and lines that will handle new higher loads
What do you mean free? The list is $4,450. I've buy one but I have four boats as it is, low enough though and this could be a fun boat to teach the kid on.Seven free Zim 15s. Tried to get them for our fleet to build a double handed fleet but there were no takers. Boats need some work like strengthening up the centerboard trunk but could make for a fun turbo project. https://sailingjobs.sail1design.com/classified/zim-z15-sailboat-fleet-listing-3302.aspx
The list price is there from a while back. Now they're sick of looking at them so they decided to just let them go for free, especially if you take all seven. The trunks need to be shored up with more glass I'm told and the rails need to be checked for leaks but otherwise they should be great boats.What do you mean free? The list is $4,450. I've buy one but I have four boats as it is, low enough though and this could be a fun boat to teach the kid on.
I'm checking on it. Great little boat to use to teach a kid with an adult onboard.The list price is there from a while back. Now they're sick of looking at them so they decided to just let them go for free, especially if you take all seven. The trunks need to be shored up with more glass I'm told and the rails need to be checked for leaks but otherwise they should be great boats.
