JimC
Not actually an anarchist.
Especially as you'd have to add corrector weights if it brought the boat below minimum weight.So for every 100 l internal volume you could "save" about 100 g... That's disappointing...![]()
Oooh, so I have floaters on the 29er I'm playing on, if I filled them with hydrogen I could improve their buoyancy by 3.6g.Tie the big parade balloon top of mast...
Consider the hobie top of mast float as precursor...
Helium fire extinguisher went off accidentally after the race started. That is not cheating, is it?Especially as you'd have to add corrector weights if it brought the boat below minimum weight.
Realistically, for a mast with stays, yeah for sure. But in theory, if the inside is pressurized high enough and the diameter is large enough, the closed off ends will be trying very hard to get away from each other and this could keep the entire tube in tension when it is just sitting there, couldn't it?No matter how high you pump up your inflatable mast a compressive force component remains. Given that the modulus of elasticity, length and moment of inertia remain unchanged then the tendency to fail by buckling remains (Euler). That is my guess, anyway, after giving it 1 minute of inebriated consideration. Then again, clown-made balloon swords do seem to be more lethal when fully inflated.
Yeah, thought provoking. Simply determine if your mast member is isotopic or orthotropic then digest this simple research paper and you will have your answer…Realistically, for a mast with stays, yeah for sure. But in theory, if the inside is pressurized high enough and the diameter is large enough, the closed off ends will be trying very hard to get away from each other and this could keep the entire tube in tension when it is just sitting there, couldn't it?
Let's stay with hydrogen, better numbers. I could not find the cost of helium versus hydrogen but I'm guessing with global helium shortages and so many efforts to make hydrogen a commercial and consumer fuel it will be less expensive now and into the future. So blow up those bouyancy bags and hulls with hydrogen.Many older classes that you sit in not on, have buoyancy bags.. perfect for filling with helium..
What ever happened to this? I'm guessing it was great in light air and perhaps not as much in heavy?And there was of course this one (Waves were supposed to wash through the double floor hull instead of being "split" by the bow):
Sorry I read about it a long time ago and cannot remember exactly what the article said. I believe the bow was closed later on.What ever happened to this? I'm guessing it was great in light air and perhaps not as much in heavy?
There have been some odd Nationals. There was one at the dinghy show one year that looked as if a snake had swallowed a selection of geometric solids: lumps and bumps everywhere so as to hit every measurement point but have the bare minimum of boat between. Its debatable whether rule writing is a sufficiently precise art that the measurement points are all that critical.Sorry I read about it a long time ago and cannot remember exactly what the article said. I believe the bow was closed later on.
