Jethrow
They come with this manual option too...If your electronics go out and you don't have power to inflate the sails, you've got a problem
Speaking of ground effect.So ~ 40% reduction of induced drag…..
See the video posted ten days ago, at 1:27Any thoughts about the Gibbons rig for a small coastal proa?
Proafile - multihull design concepts and review
Proafile - multihull design concepts and reviewproafile.com
Sidecar has a single inverted airfoil wing. Done for drag reduction, weight to windward storage, secure footing/trafficking (a proper deck to walk around on) and spray deflection/dryness, I was also aware of maybe potential downforce, especially as it was so close to the water.
Other potentially assisting factors are, that if you took slices through the aka at (AWA) 30 degrees, the sections are no longer symmetrical, but asymmetric (~ 18% thickness @ ~ 37% chord length), due to platform taper, and an AoA of ~4 degrees at outboard end due to differential aka wing droop/dihedral. Aka wing area is pretty much the same as half a Cessna 152 with nearly triple the average chord thickness. The section asymmetry increases with AWA, up to a point where it becomes useless.
Assuming 0.3 CL at 0 degrees AoA and 40% ground effect, you come up with some fag packet theoretical numbers:
16 knots TWS, ~ 30kg downforce @ 3.00m righting arm. As per video, Peanuts.
40 knots TWS, ~ 90kg downforce. Ie an extra crewman sitting @ 3.00 m righting arm.
100 knots TWS, ~ 450 kg downforce. Righting arm academic on a boat which weights just under a tonne.
No way for me to measure or calibrate, but Sidecar sits steady on her mooring as well or better than much heavier and bigger boats in the Sound and on the trailer next to the house and oriented towards the wind, the chocks which partially support the ama have never fallen out, no matter how lightly they were put in (to see what would happen). And it can get pretty windy down here, especially in the gusts.
I believe in gravity^^^^ Happy to know that the boat should stay “down” in strong winds. How about you?
So you don't believe in light boats? Only in heavy, slow boats that can use only gravity to stay steady when other external forces like wind are acting on them?I believe in gravity![]()
I have a boat that weighs half what yours does. It is also sailed routinely in very large winds (but not big waves). But it is a day sailor so yah, I do trust gravity as well as viscosity of the water to keep it sucked down and not airborne. I was only tongue in cheek for admonishing Sidecar for doing calculations--he was just preening that he knew how to do it regardless of its uselessness. Like me, he is likely just bored and nothing better to do. IN case you are questioning the winds I sail in, the screenshot is from my last sail. The windspeed wasn't the issue, it was the big shifts.So you don't believe in light boats? Only in heavy, slow boats that can use only gravity to stay steady when other external forces like wind are acting on them?
If I had the more conventional ama arrangement, those numbers could easily be mirrored, in which case, my boat would flip. It may not interest you, but others on this thread have seen multihulls tethered like kites, flailing in a storm, due to gravity no doubt.I was only tongue in cheek for admonishing Sidecar for doing calculations--he was just preening that he knew how to do it regardless of its uselessness. Like me, he is likely just bored and nothing better to do.
If you can't be bothered to do that, then neither can I.look it up,
It can weight^^^^^ It apparently involves calculation….. And gravity.
Boats have a long way to go to sail like this!
Caro Dickenson
Caro Dickenson (@carodickenson) • Instagram photos and videos
4,364 Followers, 570 Following, 532 Posts - See Instagram photos and videos from Caro Dickenson (@carodickenson)www.instagram.com
