revintage
It is light at the moment, but a 10-15kg cockpit will be built above deck level, between the beams at 140cm width. The floor will be 20cm below deck level on both sides of the hull, and will be built once the rear beam fittings are in place. Have done a preliminary weight calculation and the tri will be below 250kg ready to sail.Your center hull looks a lot lighter than mine.
