Rasputin22
Rasputin22
- 13,388
- 3,029
The Portal...
You hear stories about snakes, lizards, big spiders, etc lurking in the bowl at night. This way you can check before you sit when it's dark.
Most you can adjust the power and angle of attack. If you go full-bore, just remember to change it back to the original setting or the next occupant may get a surprise.That's a little stronger than I had in mind.
The town where I used to wurk took its water directly from the Columbia River. Just went through some settling tanks, light chlorination, then out to the town. Most older houses had toilet clams. You’d see them just down there in the channel below the bowl where the brush doesn’t usually quite reach. You’d sneak quietly into the bathroom to see if you could catch a glimpse before they… clammed up. So yeah, your junk would be dangling right down there in front of the clam. But they can’t reach out that far. Probably.You hear stories about snakes, lizards, big spiders, etc lurking in the bowl at night. This way you can check before you sit when it's dark.
Butt cleaning anthem?I've been told that it's very refreshing after certain activities, easing the "friction burns".
22 minutes ago, penumbra said:
Kind of shocked the brain trust didn't already highlight a youtube flesh pusher's prior efforts on the topic:
I’m with you on this. I’m a traditionalist. Imagine you are at a bar drinking with Robin Knox Johnson, Bill Tilman and Larry Pardey, and you say “Hey guys, I’m going to put a bidet on my boat!” Just say no.I’ve had (and will have) multiple opportunities to use a very fancy lighted and heated seat bidet in a big Air B n B house we’ll be staying at for a big out of town electrical installation job next week. Honestly, I just cannot deal with the idea of a toilet spraying water on my anus. There, I said it. I lived in Japan for four years - never there either! It sounds awful. And ineffective. And sloppy wet. There, I said that too. Ewww.
