Corryvreckan
As is so often the case with sailboats, it's the maintenance that'll get you.Desirable or Undesirable?
Saw this in a Defender email. Sorry. Please carry on.
Just soze you know... if Wifey has the helm and Hubby introduces a course correction from the other wheel... she isn't gonna be laughing like that.Depends what kind of marriage it is, I suppose. An American Protestant work ethic type of marriage, or a laissez-faire European kinda open marriage? (Notice in the pic they’re all staring at the starboard helmswoman, and smiling??!).
Carry on.
Doesn't look like there's much of a clothing budget. NTTAWWT.As is so often the case with sailboats, it's the maintenance that'll get you.
Funny enough, Gerry Clark’s book is one that I lost (inexplicably) in a move years ago. I’d recently gotten it - before Amazon was an Amazonian global sales behemoth— by purchasing it direct from a NZ bird conservancy! So I never got around to reading it. He was a nutter, a truly focused and dedicated one - the best kind!Read 'The Totorore Voyage' for another take on it.
I heavily insulated my hull and cabin sides but 'cleverly' installed opening bronze ports. I would have to say that no other piece of gear has caused me more cursing during their machining from the castings, and now they get condensation on the inside - and drip RIGHT ONTO MY HEAD in the V berth.
Jud's boat, I'd be building a hard dodger for sure before heading to Chile.
Haulout scheduled for 10 May so the plan is to install it then. It's finished except for final painting and sealing to the cabin.Yeah, hard dodger...man, you’re really cracking the whip hard! I can only do 10 projects at onceDefinitely have a design well lodged in my head for when I have the time...likely winter after next Want to focus on getting the boat dialled for Hawaii and back in the meantime. I’d like to hear/see more about your dodger.
double-sided tape is the usual way. Heat gun on the plastic to take out wrinkles. It is not very elegant, but it does the job.plastic sheet affixed somehow
I've been thinking of 3mm polycarbonate on polycarbonate standoff rings to clear the bronze trim rings, and high power magnets embedded to hold to the cabin side.double-sided tape is the usual way. Heat gun on the plastic to take out wrinkles. It is not very elegant, but it does the job.
Some friends of ours did their house every winter, it worked well for them. Big windows, too. It's important to make it as airtight as possible.I've been thinking of 3mm polycarbonate on polycarbonate standoff rings to clear the bronze trim rings, and high power magnets embedded to hold to the cabin side.
Not a real dirty weather solution obviously. Also a PITA to make which is why it hasn't happened. I should probably have set a grid of stainless acorn nuts into the cabin sides around each port opening while building but it seemed like an unnecessary lot of work at the time.
Hindsight.
Not having opening bronze ports would have worked too.
Your plastic & double-sided tape option sounds like a useful thing to try.
FKT
we did the plastic and double sided tape for quite a few years . . . but one refit we refit all the hatches and ports and windows and we then bit the bullet and did the work for 4mm acrylic inner panes (with a small band of foam tape around the edges as a gasket) - looked much nicer but worked about the same. The fixed ones we just screwed into teak trim. And used composite studs and nuts where we wanted to be able to remove them in (like in the tropics).I3mm polycarbonate
Climate isn't as extreme here, I don't have any real problems with condensation in the house even though I've got single glazed windows in aluminium frames. There's a lot of thermal mass and as I dislike being cold, I keep the house heated.Some friends of ours did their house every winter, it worked well for them. Big windows, too. It's important to make it as airtight as possible.
Hmmm - you have me thinking now. I've had it stuck in my head that the covers needed to go on the outside of the cabin. I think because I was considering them as storm shutters originally.we did the plastic and double sided tape for quite a few years . . . but one refit we refit all the hatches and ports and windows and we then bit the bullet and did the work for 4mm acrylic inner panes (with a small band of foam tape around the edges as a gasket) - looked much nicer but worked about the same. The fixed ones we just screwed into teak trim. And used composite studs and nuts where we wanted to be able to remove them in (like in the tropics).
Growing up in Saskatchewan, where the temperature range is -40C to +40C, we only had single-pane windows, so every fall we had to put the storm windows on and take them off again in spring.Some form of winter/storm windows would save me considerable heat loss so it's something worth considering. Way down the project list though, I have a hell of a lot of firewood.
If I lived in a place where it was -40C in winter, I'd move.Growing up in Saskatchewan, where the temperature range is -40C to +40C, we only had single-pane windows, so every fall we had to put the storm windows on and take them off again in spring.
I moved as soon as I could, then got my double idiot badge by going back. I'm cured now.If I lived in a place where it was -40C in winter, I'd move.
Fun fact, on winter voyages south it rarely got lower than -30C and usually only -20C thanks to the ocean not getting below -1.8C. You could keep beer chilled very nicely by putting it against the glass on the ports.
FKT
Thats one of the good things about deep frying your turkey outside in the snow at Thanksgiving...You could keep beer chilled very nicely by putting it against the glass on the ports.
FKT
I think we're all in agreement - for once - that condensation, especially condensation that drips on your head, is a highly UNDESIRABLE attribute of a boat...Condensation from my forward hatch lands right on your head :angry:
In the winter I throw a yoga mat on top of it and some old anchor chain to keep it in place. Works great and so does bubble wrap.
