Kris Cringle
- 2,278
I have not towed a Dyer at speed with water in it but we regularly tow half-filled dhows that have capsized back to the RC and tow boats in when the wind has gone flat. Never seen a problem with the existing hardware for the painter.@gkny Great tips. I'm pretty sure there isn't any foam under the aft-most seat. I should find a way to fill that void with foam or something. The bleach bottle is a good tip.
Although the Dyer rarely ships water during towing, I thought that the little bow cover would be prudent to have to keep water out. Speaking of towing, do you think the bull nose ring on the bow is sufficiently strong or should I be rigging up some sort of bridle hardware for 2 or 3 points? I've towed and even hoisted the boat onto the foredeck just by that little ring but that doesn't mean that it's smart to keep doing it.
If you are looking for a project you could do the double hull conversion that older model Penguins have done. It turns the boat into a self rescuing model.Well, the good news is the Dyer is buoyant when capsized.
I was able to right it and pump out a lot of water while I was in the water but I doubt I could re-enter without swamping it again.
Don't try to right it by standing on the CB. It'll break right off.Well, the good news is the Dyer is buoyant when capsized.
I knew a couple in the VI that had sailed down from the Chesapeake in a nicely restored sloop about 28' or so. They had the smallest Dyer (Midget?) that pretty much took up the whole foredeck on the offshore passages. They lived aboard near me in the harbor and could have been YouTubers these days and were very shipshape in every way. The name of the sloop was STEADY but what I really liked about them was that they named the small dinghy PROBABLY WOBBLY.The dinghy shape is pretty wobbly with the seats and gunwales removed, so they may tell you to do one side at a time.
What about Slack? Or Slackrity if you are feeling punchy.The Dyer needs a name. The mothership is "Alacrity." A search for antonyms yielded mostly derogatory words.
What's a good word that sums up relaxed/unhurried or moving at a relaxed pace?
