dougculnane
- 0
For another thread but this is very worthy of its own. So I started it.
Over thinking it, go with a 3 axis accelerometer and a contact switch. You know when you are on the surface, integrate the acceleration twice and you have height off the water. It should be a lot less expensive than either other option, plus you won't have to filter out the waves.Clive, very interesting design and congratulations on some terrific development work.I'm most interested in your opinion of the various altitude sensors that could be used in this application-ultrasound ,micro radar etc.
Thanks for having the guts, courage and determination to make such a trmendous contribution to foiler development!
Electronics are banned but what about fluidic logic?Electronics are banned from the Moth and I think all (ISAF classes) so it is just a side show. However I feel that it has such great potential to increase the control of the boats it will be hard to ignore.
Electronics have the ability to know if the boat is going up or down and how fast. The present systems just know how high it is now. The cost of such systems is potentially high but the complexity of them is nothing compared to the electronics in everyone's car, video, lift, wrist watch, fridge or electronic toothbrush.
As Clive indicated you can adjust the parameters on the water... So you have the chance to select the right configuration parameters, for chop, flat water, learner, sport mode etc... like your car.
Clive what are your thoughts about the future of such systems? Do you think they have a place in the sailing world and will this involve new classes or modificatins to the rules of old classes?
The problem with fluidics is that you still need a hefty power system of some sort to drive the flap itself.Electronics are banned but what about fluidic logic?
http://en.wikipedia.org/wiki/Fluidics
Note that while Wilbur and Orville have done something very cool, 26 seconds of flying time is rather minimal for sorting out durability and other issues...Note BTW, while Clive has done something very cool, 5 hours of sailing time is rather minimal for sorting out durability and other issues. Remember that at a major regattae, you can crank out 5 hrs of sailing time in one day. And a control system that lasts but a week isn't going to cut it.
Nope not at all. As I acknowledged in the other thread, I'm just an engineer who started as a MechE and then went on to electronics and software and am still in the process of saving pennies for a foiler.Note that while Wilbur and Orville have done something very cool, 26 seconds of flying time is rather minimal for sorting out durability and other issues...
If Clive's achievement were really so meager, surely you would have surpassed it by now...or are you holding out on us Baltic?
The bungee chord stores energy but lets let it pass... Actually if you think about it even hoisting your sail up by pulling the halyard on any sailboat is a form of storing energy. Anyways. We all know our little voice will not change rule 52 so lets get on with it and experiment for the sake of "out of class" fun & development. Thanks for your input.We've already been through the rule 52 shenanigans when foils were first brought into mothing - the forward motion of the boat that moves the wand and drives the flap is interpreted as 'manual power' ie. it's not a stored energy device, so the existing mechanical wand devices clear the rule.
Electronics OTOH require stored energy of some description (unless it's run by solar or wind power and even then I suspect that the device would need to have no capacitance in the circuit as a capacitor is technically a means of storing energy...) and hence does violate R52. For that matter most of the modern canting keel maxis also violate R52 as they all use engine power to cant the keel... how do they get around it?
Clive, count me in. PM on the way for offline collaboration. Cheers & thanksIf anyone else out there building 1 off foilers is interested in adding electronic control and sharing resources let me know.
Couldn't you mount a little generator between the foils like the 747s have for when they lose power, because when your not moving your not going to need much electricity, and its not stored power because your using wind power to generate it, and your wont have to lugg one of those heavy batteries around. It would have to be dectachable so that you wouldn't need a massive trolley. Also you wouldn't be limited be battery life, in case you have to launch at like 8am, then get postponed for like 8 hours. See rendering.We've already been through the rule 52 shenanigans when foils were first brought into mothing - the forward motion of the boat that moves the wand and drives the flap is interpreted as 'manual power' ie. it's not a stored energy device, so the existing mechanical wand devices clear the rule.
It's cool to see that someone's gotten out there and put into practice something that has been quietly talked about among the moth population for a little while; there was talk a while ago of simply using a wireless rotary detector attached to the wand in lieu of the existing mechanical rods and cables, with a small wireless servo installed in the head of the centreboard (and perhaps even the rudder), which would reduce the complexity of rigging a moth a little bit... make launching a matter of just plugging in the foils and going.
Couldn't the moth foiler guys just wake up and make their own class rules? electronic control, bigger sail, slightly longer hull? why continue along the same limited rule path as the lowrider moths when you are so obviously in a different plane of design and performance?Couldn't you mount a little generator between the foils like the 747s have for when they lose power, because when your not moving your not going to need much electricity, and its not stored power because your using wind power to generate it, and your wont have to lugg one of those heavy batteries around. It would have to be dectachable so that you wouldn't need a massive trolley. Also you wouldn't be limited be battery life, in case you have to launch at like 8am, then get postponed for like 8 hours. See rendering.
depends on the tuning of the system. All air/water boundary layers reflect. What matters is the frequency selected and the gain in the system. I would think a bigger issue would be signal swamping from the sun. but clearly things like Laser rangefinders have solved this.Do you know if the LED systems will reliably pick up a transparent water surface? The level of reflection could vary a lot.
