Is that the access hatch for the robot bits?
I like your thinking, Alchy. Limited to an extent by foredeck sheer height, I'd imagine. Gotta have the apparent wind flowing around the sail foot to gain an advantage, no?With the extended mast, where does it stop? I know there are volume requirements and you need room for controls, batteries, etc... but how extreme could you go? Make it basically into a catamaran with a solid connection between the two hulls. The hulls hold the crew and foils and the bottom of the boat looks like a "monohull". Just deepen the wind tunnel between the two crew hulls. Add the orange mast extender...
AM was sailing B1, then AC40 anfd now LEQ12 so in effect no difference. Using B1 there are many restrictions what cannot be modified which is why they can use LEQ12 to test the foils etc. I think if you dont modify the AC40 hull it is just the new components that you do test count to allocation.Forgive my ignorance, but how are etnz allowed to test a full-scale b1? I thought that teams were limited to either full scale 1st-gen boat + ac40 or leq12 + ac40, and by my count, etnz has run both an leq12 and an ac40. Or does their leq12 not count because the hull was that of a stock ac40?
look like open inspection panels.
Hull volumes. One bulkhead in the middle of the yacht (9m going forward enclosing 35m3 and one in the bow). There is also a limit on how the boat tapers towards the bow.With the extended mast, where does it stop? I know there are volume requirements and you need room for controls, batteries, etc... but how extreme could you go? Make it basically into a catamaran with a solid connection between the two hulls. The hulls hold the crew and foils and the bottom of the boat looks like a "monohull". Just deepen the wind tunnel between the two crew hulls. Add the orange mast extender...
Thanks, missed that.Helm pods are not at the aft (video shown that the cyclor is there), previously the helm was positioned in the middle, it is likely to re be the same, or moved to the front.
That’s because they are using 10 crew when everyone else uses 8…Thanks, missed that.
This boat has 10 pods (5+5), for 8 crew members. Have we seen that on other AC75's?
Uh, so, one or two of them switch sides?Five seats, 2 cyclors at the back, next the trimmer, then the helmsman in the front?
is there any reason why this isn't allowed either then?With the extended mast, where does it stop? I know there are volume requirements and you need room for controls, batteries, etc... but how extreme could you go? Make it basically into a catamaran with a solid connection between the two hulls. The hulls hold the crew and foils and the bottom of the boat looks like a "monohull". Just deepen the wind tunnel between the two crew hulls. Add the orange mast extender...
