thats more powerful relative to resistance?Way more powerful.
To me, Te Kahu with her over sized foils/foil arms is not optimised for speed for her length, but rather as a test platform. Her foils probably great more drag relative to her sail area - limiting her top speed.implications for power to weight/resistance.
but the size of the foils is proscribed by the ac75 rule . there is no reason to assume they are optimised for her size. "oversized" foil arms can only result in greater relative power. which would suggest superior performance ?To me, Te Kahu with her over sized foils/foil arms is not optimised for speed for her length, but rather as a test platform. Her foils probably great more drag relative to her sail area - limiting her top speed.
Not for Te Kahu.the size of the foils is proscribed by the ac75 rule
They aren't......over sized foils mean more drag relative to sail area, Increased righting moment won't make up for the undersized rig. This is a compelling reason.there is no reason to assume they are optimised for her size.
^^ Idiot16 hours ago, barfy said:
Soooo, time for te aihe now the "block" of testing is done? Wtf does that even mean
And I wonder about that based on scuttlebutt from some kiters who have lined up with both boats. I expect that some changes have been made to te aihe..didn't take 3 weeks to assemble, and as I said, develop or die.Te Aihe will be quicker on all points. With the big boat scheduled to be on the water next week, I wonder if they'll moth ball Te Kahu, or run around with Te Aihe?
If she has new wings that'll be easy to spot. Changes to the the twin skin could be on the cards as well. The only advantage I can see with Te Kahu would be speed through manoeuvers. She might get up on the wing a bit quicker, but even that's debatable. Upwind I think Te Aihe would absolutely smoke the smaller boat - higher and faster. Down wind it might be a bit closer - then may be not.....I expect that some changes have been made to te aihe..
Not trying to ruffle feathers here, but it is not as simple as that. You need to pick the set of variables that you are trying to define as being representative and then make the judgement call of which solution is better. I will try and (fail to) explain. Are you determining the reference point as being a TWS performance output? A drag scenario for a given Boat speed? Overall VMG upwind or Overall VMG downwind? The problem that is trying to be solved is uber complex. It is too simplistic to say that the foils or arms are oversized or that the Rig is undersized. There would be a sweet spot where the Lift and Drag profiles of these two primary components would be well matched. But is that sweet spot representative of the full sized class measured variant? No one here, from the very limited data we have, can do anything but speculate. The team would know and could apply correction factors to offset observed performance against expected. But be careful that the difference is identified as either scaling issue, margin of error or real loss/gain..... That in iteslf could melt most brains.Not for Te Kahu.
Given how fragile Luna Rossa appears to be, maybe the Italians need to scavenge some carbon?I misinterpreted the tolerance of 1% as being ±0.5% when it's ±1%, so actually ±65.2kg.
I'm sure things can be optimised for boat 2, I just don't see that there are huge weight savings in hydraulics. What do you think is the weight of the hydraulic systems and how much can be saved, 5 kg?
Even if there are weight savings, where could it be used to advantage? It can only go to stiffening or strengthening something in the hull as the boat must still weight at least 6,454.8 kg. Maybe you think the boats are struggling at the upper limit and need every gram they can scavenge for carbon to make the boats strong enough?
Are you Smackhead's sock puppet?BUT WHO WILL TAKE THE BLAME for this DEBACLE , The public is LOSING CONFIDENCE.,
Don't be surprised to see tham playing together. There's enough talent/skill in the team to sail both simultaneously.Te Aihe will be quicker on all points. With the big boat scheduled to be on the water next week, I wonder if they'll moth ball Te Kahu, or run around with Te Aihe?
As other have described, that doesn't mean anything. The sails on these rigs are way overpowered when they are foiling. And hull length has nothing to do with speed because they are not in displacement. I would not be surprise to see the smaller test boat be faster because of increased maneuverability, less aero drag, less weight, faster lift off and more experience in running dry laps. And of course, let us not forget the bulbed foils....lolWay more powerful.
It would be major strategic error to not sail them against each other.Don't be surprised to see tham playing together. There's enough talent/skill in the team to sail both simultaneously.
How so? Dan and the propeller heads will have mega loads of simulator data mapping their relative performance. It would simply be a distraction at this stage. Better to transfer the new tech to the big boat and get on with it.It would be major strategic error to not sail them against each other.
Is prevented by the rules... Te Aihe vs Te Kahu? fine, Te Kahu vs B2? Fine. TeAihe vs B2? banned.Now, B2 against Te Aihe in time?
