JALhazmat
Sure.. despite you lot claiming him there is an ozzy lurking under the surface. ;-)There's nothing arrogant in that statement, Gash is genuinely curious as to what the others would think...
Who is everyone else? That’s actually gone on record and dismissed them? ( apart from max before they sailed past him recently.)Really the first competitor to give a shout out to AM as a formable challenger. Everyone else seems to take them lightly.
Blimmin awesome - not much pissing around - straight into it!
well that is starting to look like they think "end plating" is worthwhileBlimmin awesome - not much pissing around - straight into it!
Fracker No2 not that flat arsed either.I think a few people need to stop getting over excited about the similarities.
Ineos B1 stern wasn’t flat.
infact theyre completely different.
The height of the topsides at the top of the curve, maybe, but Ineos topsides were straight and did not taper down to the stern, the deck layout is open compared to completely enclosed on ETNZ, no bustle as opposed to a very obvious bustle and a completely different bow profile. Chalk and cheese!
Are you implying all aussies are arrogant now too?Sure.. despite you lot claiming him there is an ozzy lurking under the surface. ;-)
Just like UK B1, but they obviously didn’t think it was worth it or they would have put it on their second boat.Would the deck design increase a funneling effect across the foot of the main? Generating more power than the other boats? As the wind passes through the slot, instead of just spilling at the back, it’s diverted down along the foot of the main?
Is it true that 60/40 power split across the main? So it would make sense to divert even more of that wasted power along the foot?
Fark look at all those sea gulls! #mustbefast
Are you sure? The crew walls on NZ2 are high enough to totally enclose the crew, where as the crew on UK B1 could easily rest an arm on the wall. Also, don’t the rules state the exact height of the mast base in relationship to the foils. If you take that into consideration, the decks look very similar, with just higher walls on NZThese shots shows just how much of the deck/floor/sole has been cut away compared to the Frackers with the mast sitting on the ball atop of the pedestal.
The only thing these two have in common is that they both float.
View attachment 407869 View attachment 407868
They saw Pete eating some fish and chips on that big ass back porch.Fark look at all those sea gulls! #mustbefast
I don't think this comparison quite works: NZ2 the crew are standing on the hull, GB1 they were in the cockpit. Walls could be similar height, but possibly shorter on NZ2 given the extreme geometry.Are you sure? The crew walls on NZ2 are high enough to totally enclose the crew, where as the crew on UK B1 could easily rest an arm on the wall. Also, don’t the rules state the exact height of the mast base in relationship to the foils. If you take that into consideration, the decks look very similar, with just higher walls on NZ
