Kiwing
Heeling into the wind for extra lift?
Starting to smell a bit like clickbait in a few of these YT channels now...
Hopefully you don't start showing signs of "Archimedean mode" and "2nd derivatives" ... dreadful stuff!Nah, it's cup-itis. Often presents with other symptoms such as intolerable over confidence and disregard for silly things such as newtonian physics.
Don’t knock the second derivative-its really good at showing you what’s really going on under all the noise!Hopefully you don't start showing signs of "Archimedean mode" and "2nd derivatives" ... dreadful stuff!![]()
Let's say LR has a boat speed of 30 knots, at a TWA of 45°. Their VMG is therefore 21.21 kn.Holy hell those look small!
Question, on the LR thread there was a post regarding how LR is able to achieve their high mode through variations of the foil flaps and main. If LR can point higher 1-2° higher, how much faster would ETNZ need to be?
Very good. Thanks!Let's say LR has a boat speed of 30 knots, at a TWA of 45°. Their VMG is therefore 21.21 kn.
If NZ were sailing at 46°, and were also achieving a VMG of 21.21 kn, their boat speed would be 30.54 kn.
Of course, this does not take into account the teams' ability to spot and take advantage of gusts, wind shifts etc.
Consider also that we're talking match race here. Even if you make up for the lower TWA you'll need quite a lot of room to tack in front of the other boat.Holy hell those look small!
The one that can’t point as high covers much more distance and hits the boundaries sooner and should have to do more tacks.Consider also that we're talking match race here. Even if you make up for the lower TWA you'll need quite a lot of room to tack in front of the other boat.
I for one think that having the same VMG of a boat that can point higher will never be enough in a match race.
In any situation where both boats are foiling, I expect ETNZ to point higher by virtue of lower drag foils.The one that can’t point as high covers much more distance and hits the boundaries sooner and should have to do more tacks.
Not necessarily, depending on how they are laying to the next rounding mark...The one that can’t point as high covers much more distance and hits the boundaries sooner and should have to do more tacks.
In theory, AM should have had the best of both worlds. They had smaller foils (similar to NZ) and anhedral foils to point higher (never got as good as LR). AM lacked the control of the main and the right tuning.Holy hell those look small!
Also if you can move across the track faster at the same vmg more options to break cover should exist.Not necessarily, depending on how they are laying to the next rounding mark...
In fact, sailing slightly higher could see you having to do an extra track to lay vs sailing slightly lower...
Sure thing, some serious vibration in the wheel when turning too, DB always seemed to be really fighting itIn theory, AM should have had the best of both worlds. They had smaller foils (similar to NZ) and anhedral foils to point higher (never got as good as LR). AM lacked the control of the main and the right tuning.
I thought of saying "could" on the tacks, it all depends on the course. I doubt there would be any time that the higher course would require more tacks (assuming no wind shifts).Not necessarily, depending on how they are laying to the next rounding mark...
