Fufkin, an honest question here. How many boats have you owned with a sail drive (farther from rudder) vs conventional shaft (closer to rudder)? I’ve owned 1 saildrive (J/109) and 4 conventional (all 30 ft racer/cruisers) and the J/109 handled better/more nimbly than any of the conv boats. You could kick the stern as easily & effectively as any of the others. Might have had to use a touch more throttle, but lack wash over the rudder was never an issue. Maybe part of that was due to the J’s more modern/deeper shape compared to the “mid 80’s” rudders on all the other boats. I agree you couldn’t “walk the stern” using prop walk. But then again, you could back much more easily, so to me it’s win for the more forward location. In 40+ years of boating, there’s been only 1 time I’ve had to spin a boat 180 degrees using reverse prop walk and forward stern kick.Sure but why give up on extra stern handling by not putting the prop closer to the rudder? Its a small boat so the difference between 'kicking the stern' and throwing a line or what not might be somewhat academic. Nevertheless, looks like the fellow owner who Bull consulted with opted to put the prop further aft and below the 'mystery compartment'. Also, as far as drilling holes, a small hole in the bulkhead and you can easily put the battery closer to centre in the 'storage area', if desired.
BTW, you can turn an outboard but you can't turn a fixed prop. Luckily for me I swore off auxiliary outboards on a sailboat 40 years ago so its a distant never to be revisited memory.
My experience says go with the more forward location (centered weight, less drag, no loss in maneuvering forward, gain in backing), so I’m curious about what in your experience says differently?
Crash
