Jethrow
Except you would have to put some form of spacer between the "two hulls".there doesn't seem to be any foam between these two hulls ... so through-bolting should be possible
maybe, maybe not. depends where. I bolted through with no spacer for new handrails. but other parts of the overhead, I think yes, you might.Except you would have to put some form of spacer between the "two hulls".
pretty sure this isn't the case. fyi there is a very active Etap owner's group in the Netherlands. in case anybody here speaks Dutch.Neat little boat with loads of cool features and sails well, but unthinkable foam core construction means if any moisture gets in, the whole core steadily turns to mush.
Rare but not unheard of on late models, rampant in early ones ... The use of expanded foam is NEVER structurally good sense on a seagoing vessel.
37s definately has foam in the overhead / deck. 120mm from memory.However, there is no foam between the overhead skins that I am aware of. the idea is that if the boat is holed - or a seacock compromised - you will still be able to sail the boat and inhabit the interior. crazy shit. really. and my boat is not especially tender. it does just fine in SF bay.
I can see how that would be nice from an insulation pov. but it has nothing to do with the 'unsinkability' of the Etap, as that must be placed below or near the waterline to be effective. so any foam in the overhead a completely different story. maybe you are just thinking foam cored deck. which is true.37s definately has foam in the overhead / deck. 120mm from memory.
I agree it adds little towards unsinkability (except in extremis I guess). I'm also unsure how structural it is, again from memory it seemed well bonded to the deck, but not to the inner lining. I replaced a vent and needed to tighten cleats up forward, so had a good look at that area.I can see how that would be nice from an insulation pov. but it has nothing to do with the 'unsinkability' of the Etap, as that must be placed below or near the waterline to be effective.. maybe you are just thinking foam cored deck. which is true.
I find the all the foam a bit of an odd choice - until I don't. I guess. lol.
