Dex Sawash
Demi Anarchrist
Also got a SLO SAILS Laser2 top cover, doesn't have holes for anything on top but all the spars fit underneath on Intensity foam spar blocks, $200ish with bottom strap with buckle upgrade.
[ICODE]
[/ICODE]On the furler, the small diameter of the mast, plus the increasing lead angle as the wraps move up the mast, are definitely a disadvantage.
Def want to replace the torlon balls to get the furler back in spec. I use a very small diameter furling line and have zero problems furling in and out. My mainsail is made of .6 poly spinnaker cloth so it furls super easy without creasing.
My boat has the centerboard carpet and it works well. As noted above, I cut 1/3 off the board. its faster upwind and down, set it once and forget it.
My bearing plate is some kind of starboard plastic, not aluminum. That's a pisserWas out playing with the 14.5 in 12-15, and some 2-3’ waves. Lots of fun.
I did have one problem when the furler drum sheered the plastic nub that holds it under the aluminum plate, and bounced out of the step. The base of the mast came off the pin in the step, and then bent that pin. I re-bent the pin to align with the hole. But now there’s nothing to hold the mast in the step.
How are you guys keeping the mast in the boat? I was thinking of adding eyestraps to the drum and aluminum plate, to ensure it’s secured to the boat.
Thanks
Thanks
That means the furler is out of position on the tube or the mast plug at the bottom is not fully insertedOddly, the upper key does not drop into the keyhole when aligned. It sits above it, even with the mast fully seated on the pin.
