On our Olson 30 ,we used a keel attachment rod with a ring. You could check with Olson 30 web site.Anyone using the keel lifting point to lift the boat of the water, so far we been using straps, but it would be much easier so use singel point lifting, any thoughts or experiance on the topic?
You mean like the red lines you can clearly see in the photos that run from the hook aft to the the stern pushpits and then forward to the winches? OK.Or at least have someone at the bow pulling down on the bow line. The best method is to have 2 lines run aft to the stern pulpits( no cleats on a Fareast).
We weren't lowering the boat when the above photos were taken. Agreed, the red rear lines weren't tight enough but we couldn't know that until the boat was lifted. The bowline was pulled down tight and two of us lifted the transom to level the boat out when we lowered it on to the trailer. None of us had previously lifted the FE28R so we were pretty much making it up and following the manufacturers instructions as we went. The crane never touched the mast and the boat made it safely into the correct position on the trailer so we achieved the right outcome. Lowering the mast was done with a taller mast-crane and was also completed without incident.Yes, like those red lines that weren’t tightened up enough. I was just stating that a bow line pulling down would help balance it. I didn’t look too hard at the pics last night, but I do see the slack bow line now. No harm meant from a former 28r owner.
Thank's for your reply and photos. You are mentioning "manufacturers instructions". I have been looking for that, but not been able to find any. Any ideas where to find those?We weren't lowering the boat when the above photos were taken. Agreed, the red rear lines weren't tight enough but we couldn't know that until the boat was lifted. The bowline was pulled down tight and two of us lifted the transom to level the boat out when we lowered it on to the trailer. None of us had previously lifted the FE28R so we were pretty much making it up and following the manufacturers instructions as we went. The crane never touched the mast and the boat made it safely into the correct position on the trailer so we achieved the right outcome. Lowering the mast was done with a taller mast-crane and was also completed without incident.
There were several laminated instruction sheets that came with that particular boat covering rigging, rig tuning, mast removal, lifting etc. I believe they came from the Australian distributor.Thank's for your reply and photos. You are mentioning "manufacturers instructions". I have been looking for that, but not been able to find any. Any ideas where to find those?
Take a look at the IMX 38! She has a steel "skeleton" structure, or "spider", as we called it, taking the loads of mast and keel transporting them into the hull skin - pretty much a copy of the design philosophy from Russel Bowler structural innovations in the 18`skiffs and the following Farr designs. The central lifting strop attaches at this structural element via a shackle, then passes though a service screw fitting in the coach roof onto the crane`s hook. We used an industrial kevlar strap, protected by a protective sleeve to avoid damage at the cpassing point on the coach roof.Anyone using the keel lifting point to lift the boat of the water, so far we been using straps, but it would be much easier so use singel point lifting, any thoughts or experiance on the topic?
Hey Julian where’d you charter the FE28 from ?I think it's a Dutch specification, BTW. I'm sailing one in a 2 weeks time at Arlie Beach, but it will be trailer launched long before I get there. We don't own it, we just charter it, but they are nice boats to sail, this will be the 3rd time, you have to keep the bow down so they don't pound!
Ergonomics is great, and I say that as a quasi Industrial Designer.
Cheers thanks , maybe next yearGT did it (not I), guy in Brisbane with a very Dutch name, the agent here I think.
The name is something like Guriut and I am quite embarrassed that I can't spell it properly.
I will be sailing with him on the 12th but GT chartered it for both Airlie and Maggie.
(I can't do Maggie)
This will be the 3rd or 4th time we have done it.
