LB 15
Cunt
Well as it turns out, no they didn't.Are you saying there are only 2 bolts holding the keel on??!!
And given the cassette design, the lateral loads are taken by the cassette, the bolts just carry the vertical load - the weight of the keel and bulb. As the boat heels, these loads decrease too.Yeah, looks like 2 12mm SS bolts. that's about 16 ton capacity for a 900kg keel, should be sufficient.
This is true in the ideal world. In the real one, given the gaps and deformations, the bolts may be subject to not negligible parasite bending/shear stresses, the more if they are loose.And given the cassette design, the lateral loads are taken by the cassette, the bolts just carry the vertical load - the weight of the keel and bulb. As the boat heels, these loads decrease too.
Yeah I was thinking the 16 ton was static not slamming over waves & tip outs.And given the cassette design, the lateral loads are taken by the cassette, the bolts just carry the vertical load - the weight of the keel and bulb. As the boat heels, these loads decrease too.
No doubt you’re right but if one bolt can carry 8 tonnes and the keel and bulb weigh, say 1.5 then that’s still a large safety margin.This is true in the ideal world. In the real one, given the gaps and deformations, the bolts may be subject to not negligible parasite bending/shear stresses, the more if they are loose.
Okay, I'm no expert but I use 2x8mm SS for each one of my clutches so each bank of 6 cabin top clutches uses 12x8mm, which makes 2x12mm for a keel sound low, even given the differences in the directions of the loads & underlying structures.Yeah, looks like 2 12mm SS bolts. that's about 16 ton capacity for a 900kg keel, should be sufficient.
Just as a comparison, although for a totally different type of joint (flanged) and fin section (much larger) : my J/92S has 4xM27 SS bolts for an 1100 Kg keel. J/Boats recommends 350 Nm torque. By comparison with Farr280's recommended value at 99 Nm, and assuming same bolt material, Farr280's bolts should be around M18 size. I would be surprised if FarrX2 had just 2xM12. Too small in my view. Unless they use a much stronger material.
Yep, you have to assume that one bolt carries all the load. so still less than 20% of the bolt proof strength including dynamic loads. Well within the fatigue limit for SS. All seems to point to some type of manufacturing f up, stripped, overcut thread?No doubt you’re right but if one bolt can carry 8 tonnes and the keel and bulb weigh, say 1.5 then that’s still a large safety margin.
