ARK OAR AND PADDLE COMPANY.Nice!
What are the thoughts on the power plant?
J
8FT SWEEPS!
J
Thats good, I dunno if people are gonna want grinders and a wheel. You can feel the boat so much better through a tiller. Besides, less parts to malfunction with a tiller. Been on a Farr 40 in SF bay that busted the steering cable outside the Golden Gate by Mile Rock....not fun. And as for the grinders...c'mon. Boat is to small for them. Frozenhawaiian is right, the TP52s are using tillers, Rage had a tiller, I've even seen a custom 65 footer (older R/P design looked like) with a tilller. Maybe its just that I am not a fan of wheels haha.
Well stated:
A lot of what you see will be optional items; the designs reflect the boat with all the options.
Simpler is cheaper, lighter, better. Option is good idea. Those that want it and don't care about price, weight will take the option.Current decision is to make the stock boat with a tiller. Wheel/wheels will be options as will the grinder.
If the draft is over 7'-6" you will kill the bulk of Great Lakes sales. Better would be even less. Outstanding would be 7'-0"
Or an optional "working" keel lift that reduces 9' draft to 6' for use while approaching the dock and at the dock. The Farr 36 attempted this but I don't think any were built before Carroll went belly up. (Not just a system for hauling.)
some people have mentioned the need to be able to readily attach an emergency tiller or spare emergency rudder during offshore racing.why not a flat transom and just out the 2 mounts for an emergency tiller on the transom?
a 43 footer with 7 foot draft is a cruiser. so make it 8.5 - 9'.If the draft is over 7'-6" you will kill the bulk of Great Lakes sales. Better would be even less. Outstanding would be 7'-0"Or an optional "working" keel lift that reduces 9' draft to 6' for use while approaching the dock and at the dock. The Farr 36 attempted this but I don't think any were built before Carroll went belly up. (Not just a system for hauling.)
I agree deeper keels are better and love upwind machines with deep keels. I also live in my real fresh water world.a 43 footer with 7 foot draft is a cruiser. so make it 8.5 - 9'. cost, weight and complexity of making a lifting keel system workable while underway is absurd. would probably increase cost of boat by 25%-40%. a lifting keel would be good, but expensive. (However, you could use blocks and purchase with a battery powered truck winch if you wnat to eliminate the complexity and cost of a hydraulic system.)
Keep it a deeper keel, but just make the keel easy to remove. fin-into-slot and bolted on is something to consider. removal is as simple as undoing bolts and lifting boat (in slings) off of keel.
Bob,Current decision is to make the stock boat with a tiller. Wheel/wheels will be options as will the grinder.
Like this one, only a bit longer...? Rig also looks very modern and agressive.Bob,
How about a nice broad aft sections with a hint of a hard chine and plenty of volume in the nose? My wish is for this boat to be a modern-day sled that can crank big numbers with a Asymmetric Kite on Transpac-type races and keep up with the SC50s.
you got my vote here .Another FT to chime in on.....
Every element of this boat should be SIMPLIFIED.
No grinder please.
No wheel please.
Single backstay please. Whatever ingenious configuration to provide the biggest main with a single back would be greatly appreciated.
The world needs a fast simple boat this size that provides pure sailing pleasure at a relatively reasonable cost. Simplification also eases the need for maintenance and long term maintenance/upkeep.
Nice lines Bob.
Bob,Bob it is a Soto 40 being built in ARG. I have a meeting with the builder and a prospective owner this coming weekend. I can tell you that it is a pretty sweet ride from what I have seen.
http://www.sotoacebal.com/d63.htm
Sorry not to take thunder away from your boats. I really like what I have seen in the FT's.
We will offer the dual helm as an option. Allow the class to decide on whether to add penalty weights if you go with the standard version.so is it now tiller only?...looks clean...backstay hydraulic or blocks?
