Bob, Bill, Loco,
DO NOT make two different keels, and DO not make the standard keel too shallow. you are totally compromising the performance of the boat. there is no better way to increase perfomance and reduce crew than high stability. that means the deeper the draft the better.
The J105 had a shoal draft option and on mass all of them changed to a deep draft one year. the shoal just had really really shitty performance. dont make the same mistake.
as for how to engineer a lifting keel, just put it in a floor to cieling, fitted, keel box. keeps it water tight, distributes load, etc. have some water tight access hatches to access the bolts that hold it up/down. then use an electric winch with some ihgh stregth line. simple. efective, and you will only really use it to get in and out of the dock. offshore or racing you bolt it down and GO.
