Made a decent carbonara for dinner tonight. I use cream, bacon, egg, and a crap ton of garlic. No onion or peas. We had parmesan on hand, though I prefer to use romano it's not always available.If you like bacon with pasta, this recipe for carbonara from my Italian father-in-law is really good. He says it is more of a peasant dish than the version you get with heavy cream and peas. I've made this with thick cut peppered bacon instead of prosciutto and it is really good as well.
1 pound dry spaghetti
1 large onion finely chopped
4 fresh large eggs
8 ounces prosciutto
1/2 cup freshly grated Parmigiano-Reggiano
1/2 cup freshly grated Pecorino
Extra Virgin Olive Oil
Freshly cracked black pepper
Sea salt
Heat a large skillet over medium heat. Add a generous amount of olive oil to the skillet (there should be about 1/8 to ¼ inch in the pan) and add the onion and sauté until completely softened. Add the prosciutto and saute until prosciutto is cooked through (I like to cook until the prosciutto is starting to crisp). Turn the heat to low.
When you put the onions on to saute bring about 6 quarts of generously salted water (it should taste like the ocean) to a boil, add the spaghetti and cook for 8-10 minutes or until al dente.
In a bowl whisk the eggs and the cheeses until well-combined.
This is the part of this dish that is a bit tricky and should be done fairly quickly so the pasta does not cool off as the residual heat in the pasta is needed to cook the eggs. When the pasta is done, drain and reserve a ½ cup of the cooking liquid. Leave pasta in colander. Add all the contents of the skillet (onions, prosciutto, and olive oil) into the pot that pasta was boiled in, then add in the pasta and place over low heat. Toss to combine all ingredients and heat through for a few seconds. If the pasta appears too dry add some EVOO and heat through.
Remove pot from the heat and slowly add the egg mixture to the pot stirring quickly until the eggs are incorporated into the pasta (stir quickly to prevent the eggs from scrambling . . . some actually prefer to let the eggs scramble a bit). Add about half of the grated cheeses and toss some more. If the sauce seems too thick, thin it out with some EVOO or some of the reserved water.
Season liberally with freshly cracked black pepper and additional grated cheese to taste.
I love a good Chicken PiccataI also did a good chicken piccata this month. Also simple but good. You'll need a couple of chicken breasts, flour, butter, lemon juice, white wine and capers.
I prefer to mash chicken breasts with my hand on a cutting board and slice them horizontally in thin slices over pounding it thin. WAY thinner than the slices in that link BTW. You need a sharp knife and a careful hand, but if you do it right it's very thin and fork-tender. And you can't over-pound it and make holes, it takes less time, and doesn't splatter chicken bits all over the place.
Slice (or pound thin if you must...) pieces of chicken breast. Flour lightly, shake off the extra flour. In a hot pan, melt butter and brown up the breast cutlets. Put a plate in the oven, and put the oven on warm. It's going to take a few rounds of browning to do all the chicken, so stack the pieces up on the hot pan in the oven while you do them all. You may need to add more butter to the pan between batches.
When the chicken is done, add about 1/3 cup of lemon juice and 1/3 cup dry white wine to the hot pan. Also pour in the dripping and collected juices from the chicken plate. Cook the sauce a couple of minutes, while stirring and scraping the sides of the pan to get all the stuff into the sauce. Add capers to the sauce, and dump the sauce and capers all over the plate full of still-hot chicken.
I like the cut vs pounded every time, particularly with a big chook.I also did a good chicken piccata this month. Also simple but good. You'll need a couple of chicken breasts, flour, butter, lemon juice, white wine and capers.
A bound breading seems like an entirely different thing than a simple flour and saute, and the garlic would change it. Probably good, too.I like the cut vs pounded every time, particularly with a big chook.
Instead of just flour, try a 3-way mix. Flour them, then dip them in a beaten egg/water mix, and then into panko (Trader Joes have it) seasoned with garlic powder.
Then do exactly as you say.
Mmmmm....
This looks healthy and delicious.
How can you tell it's Portuguese? Does it smell like stewed Whelk or something?
Because I made it. My family comes from the Azores, and I used an old Portuguese recipe when I made it.How can you tell it's Portuguese? Does it smell like stewed Whelk or something?
Plesae sharre it, I licke to backe alle kindes diffrent breades.Because I made it. My family comes from the Azores, and I used an old Portuguese recipe when I made it.
AH! I thought maybe it had an accent that tipped you off....Because I made it. My family comes from the Azores, and I used an old Portuguese recipe when I made it.
