craigiri
Being as it's a Rocket thread, I should at least mention that I've had mine out sailing 4 times or so here in Sarasota, FL.
I totally have the hang of rigging it - I can get it down from a 3rd level rack and have it rigged in less than 15 minutes. It will go a little quicker if I try a split pin instead of the ring for the rudder - that slows me down big time. I leave the sail on the spars - wrapped around, so it's not hard to just pop the mast on and rig.
Readers should remember that I have never owned a Dinghy nor sailed Sunfish. My present experience was on a stub keelboat and Sprint 750. This matters a lot, of course! I'm 68 and 180 lbs.
My first two days had fairly decent winds - 10-12, gusts as high as 18. Sarasota Bay can be quite choppy with currents from all directions as well as powerboats and jet skis, so this is NOT lake sailing. Far from it. But it's not Outer Banks ocean sailing either!
I didn't dump the boat so that's a good thing. I was able to handle it in the gusts easily enough and feel confident that anything under 20 MPH gusts is doable. I'm not tempting fate w/heavier since I am usually alone - both in the boat and in terms of nearby boats watching me.
It points well and tacks easily in all conditions I was in. I compared my pointing with a keelboat and I think I did as well or better (it was nearby). I can't judge my speed but it seemed faster than the (likely slow) 22 foot keelboat w/full sail.
I keep quite a bit of sail forward of the mast - the mast is almost at the beginning of the viewing window. Whether that is right...I have no idea, but it feels OK.
It doesn't feel at all short on sail or power - winter sailing down here tends to have some good breezes and I don't seek out stronger winds as much as I did with my Sprint 750 (yet!).
As always, it's fun learning new things and the boat keeps me busy by the second.
It would seem that the Rocket is very similar to the other models of Sunfish, etc - so I doubt we Rocket Owners are going to have "new things" to share. The larger cockpit is nice - a bunch of sunfish sailors have looked at it and agreed they'd like that space. The grandkids are coming down soon so I will have a chance to put a kid or two in it and use the cockpit more. As of now, I use it mostly for a bag at the rear which is put up on a small hard foam pad (keeps it drier).
Not much else to it - if you know sunfish or phantoms, you will know the rocket. The lighter weight helps...I am sure...with my back and the 3rd story rack and launching, etc.
I have not rowed it again although I will because I want to try the different techniques.
