Furling boom
badia420
69
Barcelona
Hello!
Father in law just bought a 1999 Swan 56 and is currently updating the hardware and all.
It will race but since he will be sailing always short crewed, or with sailors his age (65) we were thinking about a furling boom mainsail.
What do you think and recommend? brands? systems?
Thank you!
mgs
canoeman
1,265
320
maine
If it’s got a powered winch for the halyard put a little money into a good lazy jack set up (or Dutchman or stack pack whatever) and go sailing. If it then is a problem to deal with the main consider a furling boom.
Leisurefurl is the standard I’ve seen. You need to be paying attention when furling, more so than with a headsail, but they work well. They currently are working with some long lead times.
Schaefer also has a furling boom that’s good, might not look as elegant though.
 If you’re going the carbon boom route all the spar makers seem to have their own version.
slug zitski
1,624
worldwide
Hello!
Thank you!
Hard to say , I’ve sailed with several brands of roller boom
speak to a rigger , they will be familiar with the market and booms that are suitable for swan
all roller booms are a pain in the ass
not a good choice for a racer cruiser
roller booms are best for day sailers
badia420
69
Barcelona
I agree, but we are talking about a swan 56, old design with winches in the mast area, not all redirected to cockpit and amateur and "old" crew.
And also it will be cruised and daysailed shorthanded/solohanded.
Just looking at all options to simplyfy and make easy the handling of the mainsail. Genoas are in an electric reckman furler.
Also how does oen reefs in a furling boom?
mgs
canoeman
1,265
320
maine
To reef you just furl the boom.
I have yet to see a furling boom set up with the main halyard still at the mast. If he’s singlehanded is he really going to go forward to raise/reef/lower the main?
A powered winch is highly recommended.
slug zitski
1,624
worldwide
Many different systems
the pictured boat has fully automatic furling
captive hydraulic winch in bilge , hydraulic boom roller and a boom vang with level sensor
press up button , sail up
press down button , sail down
expensive
you should visit a boat show …METs or Düsseldorf and review options
NZK
814
Roaming
In-boom furling at least allows the use of full length battens so you maintain a decent roach in the main - better than in-mast for actual sail shape.
Maybe contact EMV in Badalona/Palma who are the Swan Global Service agents, they're probably a good starting point for help on what integration is possible.
https://www.emvmarine.com/
slug zitski
1,624
worldwide
Those full length battens you like are the curse of a roller boom
normally the compression load from the full length batten is transmitted to the mast via a batt car.
Roller booms don’t have batt cars to handle compression  , the batten ends at the luff tape
The batten compression can tear up your luff tape in  one day
jibing the main is very hard on the batten end of a roller boom
Trovão
in-mast can have vertical battens that help quite a lot with roach shape...
