Do you have any sort of pictures of the tack setup?I designed and started to install a similar system on our 50' cruiser. External 6mm Dyneema halyard to an external hanging lock, Facnor FX4500 furler, 3:1 tack line to a Karver KJ jammer. Life changed while we were waiting for parts from Selden over the winter and we sold before I finished the system. So no practical experience with it on my boat, but I'd tried all the pieces on anothed boat and they worked well. I especially liked the KJ Jammer. Didn't slip like a typical clutch and no need to run a loaded line (tripping hazard) back to the winch.
Is there only a single shackle holding both the red and blue Ronstan blocks in place? If so, do you have issues with the blocks binding and the line not running fair? Or am I just blind and there are two shackles in there?Here is my removable 3:1. I've gone through a few variations, now using a dogbone instead of the soft shackle to attach to the Ropeye deck fitting as this tack fitting is used for two different tack points so ability to switch quickly is important.
Hey. You stole my photo that I stole from the internet!I have two 3:1 setups to Karver Jammers mounted at the furlers on my Express 37.
The A sails off the sprit is not on a halyard lock, and the staysails are on a Karver KFH 2 lock with the same 3:1 to Karver Jammer. Jammers can be released remotely from the cockpit with trip lines. I find it a great setup for Single or double handing.
Nice Picture tDot!
Not my boat, but it's probably because below that there is no access inside to be able to put the backing plate/nuts on.Why was bobstay mounted so high on bow?
