The float rudder linkages do look suspect...lots of articulated and moving parts, the rudder spanner looks too slender?.........only the main hull rudder was being used due to some sorting needed on the float linkages.
That shot is a beauty! And damn that is a flat cut for a chute. Is that designed to be a reacher or are you using that as a runner for downwind VMG sailing?
Mundt is right, looks like a code zero, which rates as a spinnaker under OMR. Venom on the OMR website is rated with a spinnaker, no screecher, but the rating shown must be suspect anyhow. Since when does a top of the line 42 ft Grainger tri rate less than a 24ft Diam tri?That shot is a beauty! And damn that is a flat cut for a chute. Is that designed to be a reacher or are you using that as a runner for downwind VMG sailing?
She is a beautiful boat and a credit to Tony Grainger and Jamie Morris the builder.That shot is a beauty! And damn that is a flat cut for a chute. Is that designed to be a reacher or are you using that as a runner for downwind VMG sailing?
Very nice; thank you.She is a beautiful boat and a credit to Tony Grainger and Jamie Morris the builder.
This is the Hounds Code Zero, meant to be flown off the inner point on the bowsprit, at the time of this photo the boat was still missing two sails from the inventory, the Screecher off the same hoist and inner tack point would have been the sail for this hot angle.
Attached is the design of the sail in this image, off the correct tack point the foot is not so tight. it can be used through the whole wind range, sail suits 55-90 AWA, so shy reeching in the light right through to being the sail for VMG runnning angles in 22- 30 knots. This sail measures as a Screecher in OMR.
The boat now has a new sail we named the MHA3 which is also measured as a Screecher on OMR for 65- 110 degrees AWA, and to be used from 0-22 knots true.
Quite similar sails by design as the boat always pulls the apparent forward of the beam, but different areas and fabric engineering.
The Zero is a tight luff bottom up furling sail, and the A3 eases the tack up to set the slightly soft luff and you tack down tight to top down furl with the cable in the luff.
The Screecher is yet to be done for the boat and would complete the sail wardbrobe.
The MH A3 was added into the OMR spreadsheet under spinnaker and throwing the numbers out, attached is the correct OMR with the sail added into the screecher section and no spinnaker. I think the boat will sail to this rating quite competitively offshore.
Just remember the crew weights are not added into the spreadsheet until an event, so the likes of a Diam 24 rating drops significantly when you insert the crew weight.
So you need to add in crew weights to compare properly.
So the A3 is a top down furl....? The cable I guess spins inside the luff tape..? As opposed to the older version where the cable is always tight and the luff of the sail is longer than the cable...? If so is this version having less problems with furling than external cable...? This also means a little less sail area as the luff is shorter than it would be an external cable with A3. (When sailing the tack is 0.5-1m higher off the prodder when sailing deep...? ) I would like to know moreShe is a beautiful boat and a credit to Tony Grainger and Jamie Morris the builder.
LOL, I was thinking of the same questions for @Lowgroove if its not imposing. I was guessing (?) that its a top down with an internal cable and the theoretic lost SA compared to an external cable not an issue if the boat is so fast that even VMG running the apparent is forward of 90.So the A3 is a top down furl....? The cable I guess spins inside the luff tape..? As opposed to the older version where the cable is always tight and the luff of the sail is longer than the cable...? If so is this version having less problems with furling than external cable...? This also means a little less sail area as the luff is shorter than it would be an external cable with A3. (When sailing the tack is 0.5-1m higher off the prodder when sailing deep...? ) I would like to know more
That pic shows extreme (45 degrees?) flare on the main hull that I hadn't noticed or forgotten about, but a thread review shows it's been there all along. I wonder how that behaves in swell where sudden, massive changes in displacement could result from each passing wave?
