PIL66 - XL2
I only have experience with the Harken system....Thanks for that, what mainsail locks do you use and recommend, the ones with trip line or the one that are self-releasing? Good jib and screecher locks are plentiful and I use Karver ones but mainsail ones are more difficult to find in my view.
Advantage on a multi up to 50ft is not much... The advantage for cable less upwind sails on the bigger boats like Comanche is huge. Weight saving is one.. the other is the ability to get it up and down much quicker with 6 less guys on the fore deck. This used to be hanked on so imagine the drop when the breeze kicks and having to bag this sucker on the leeward rail then get it back to the cockpit... now two guys hook it on and control the roll for the hoist and then retrieve it when done... also meaning the time it takes to change down and up a gear is way less... plus It is stored in a shorter bag. It is very cool........ WIN WINThe use of the word Cabless seems flat out wrong to me, so far even if they were originally test sailed with no cable all rhe sails I have seen have ended up with luff cables, all be it smaller, but still cables, being called by ither names. Holding a mast up by a sail only is an amazing feat but does not interest me much. Having to keep your expensive forestay still there in front of the sail taking some of the load and therefore allowing sag in a sail is also not something I am interested in (unless looking for more entry depth)and we are seeing this as a current solution being used for the J1 on the Big boat Pil mentioned I believe. combined tack load is therefore actually no less in this example for the J1, so what is the advantage for an upwind sail?
https://yachtracing.life/doyle-sails-cableless-headsails-deliver-results/
Yes you get used to it....The trip line just needs to be held down / open while the lock goes through all reef points when dropping at the end of the day...The reefs complicate it as needs to lock at different heights unlike all the front sails.
