Nearly 2:1The rig does a look a little small. For reference, a local Corsair 43 was refit early in life with an 80' rotating carbon rig for better performance in light air. The Corsair 37RS has a 51' rig. In both cases the boats are a good bit heavier than the Grainger, and often sailing in areas with less breeze than Venom. Still, it would appear the floats can support a slightly larger rig, potentially with rig canting an option for race mode![]()
Is that AUS money or US? Could that be correct? - seems very stiff even AUS $....Re; Cost,
I've heard from a very reliable source (close mate of T.G.) that $2.5 million is the money.
Surely its a floating tack and the main hasn't been pulled all the way up? The sail looks like its on the boom so should be able to go up and have luff down adjustment. If not the sailmaker needs a measuring tape.Lotta mast (weight aloft) sticking out the top of that square top.
Short changed on the provided sail dimensions?
If anything this sail could have been 50mm shorter on the luff, she can go full hoist, just a halyard that needs be be pulled up harder, great shots, she's a beast.Surely its a floating tack and the main hasn't been pulled all the way up? The sail looks like its on the boom so should be able to go up and have luff down adjustment. If not the sailmaker needs a measuring tape.
