Tacoma Mud Flats
Have star, will steer by
My invention consists of a roll of connected sheets of paper for toilet use, said roll having incisions at intervals extending from the side of the web toward the center, but not meeting, and terminating in an angular out, whereby the slight connection left may be separated without injury to the connected sheets. A difficulty with rolls of this character as heretofore manufactured has been due to the width of the bond uniting the sheets, which it has been necessary to make of considerable strength to Withstand the tension of winding, but which it is desirable should be as trail as may be when the roll is unwound, otherwise the sheets do not separate with certainty and many of them are torn. Attempts have been made to remedy this by incisions in the bond that should not weaken it longitudinally; but such incisions avail little unless the sheets are pulled in a certain direction, a condition the user seldom considers or is aware of. In my improved roll I overcome this wholly by reducing the bond and terminating the lateral incisions in an angular cut, removing all liability of injury to the sheets in separating them. With this construction, one sheet may be separated from the next without liability of the incisions turning in a direction parallel with the web and tearing off a considerable part of the contiguous sheet. At the same time, I wind rolls containing any desired number of sheets.
US465588A granted to Seth Wheeler of Albany, New York
Thanks Seth, you made eating corn on the cobb fun again.
