eastern motors
- 154
You would have servants on board this boat.Not a fan of house stepped mast. Cannot get to it without going on the roof.
Come'on @Greenflash say it ain't so.
That 78 looks like a deck sweeper. Downgrade imo
Ah ha! It's finally happening - aft helms on a Gunboat. Here's the deal: We will do either only inside, only outside or both (Since we believe tiller steering won't be great on a boat this size). Many people love to be outside when the weather is nice. Many are happy for that the be the only spot, with a good nav station, throttles and pilot controls inside.The renders are in.. I'm guessing there will be many tongues wagging about the steering position at the rear. Be interesting to see what is going on in the forward cockpit too. I think in the 68 they wanted the mast further back and have achieved it with the 80.
https://www.gunboat.com/series/gunboat-80/
Sorry mate, VPLP wanted to put the 68 rig on the roof and we felt it was too much of a step (excuse the pun!). We ended up moving it half a meter aft.Not a fan of house stepped mast. Cannot get to it without going on the roof.
Ha ha - We call that the "fly lounge", it is to be used at anchor only - if it were to be used when sailing it would mean raising the boom higher, and that comes with performance compromises. You have the choice of a flat roof covered in solar, a fly lounge or my favorite: use the fly lounge volume to create a SUP/Kiteboard/Surfboard storage box, with a hard composite cover, that can be hinged up. This cover can be fully flush and covered in solar panels.flybridge on a GB!
I figured that was the reason. You loose a fair bit of volume if you bring the forward cockpit aft.Sorry mate, VPLP wanted to put the 68 rig on the roof and we felt it was too much of a step (excuse the pun!). We ended up moving it half a meter aft.
We are creating a giant salon on the 80, so the ratio really doesn't work well anymore, you would have a long boom and huge main that still has to be handled by 2-3 crew, so there is compelling reason to put it on the cabin top and create a little plinth for halyards in the cockpit. The aspect ratios are better, the "J" is much bigger allowing for a much bigger solent/jib/J2 on a self tacking track in front of the rig. Our forward cockpit has been completely redesigned to be as much of a lounging area as a working area. Other than the usual sail ties for reefs, there is no reason to go to the roof as all the line handling and rope-holding is done at the cockpit level.
Does the track run just in front of the mast, on the roof, or in front of the forward cockpit, or somewhere else I haven't thought of?much bigger solent/jib/J2 on a self tacking track in front of the rig
It seems like things are picking up, but realistically they’re averaging less than 2 68s a year. I can’t believe the business model is built on that low a volume, but maybe it is with the dramatic increase in prices. Only GLY knows for sure…Hadn't picked up on that, wonder if they will bond the bits together?
Seems like Gunboat is doing well though with GB68 06 in build and sounds like the orderbook is filling up too.
https://www.gunboat.com/gunboat-news-nov2021/
It’s all about out-doing your friends with the Hanstaiger!I am amazed the market for very expensive cruising cats exist just for owners on weekends?
I wonder if supply chain probs haven't hindered production, I have a sneaky suspicion they might've up the price a bit from what they originally was thinking they could get for them. Been a bit of a surprise that none of the 68's have gone with an outrageous colour so far..It seems like things are picking up, but realistically they’re averaging less than 2 68s a year. I can’t believe the business model is built on that low a volume, but maybe it is with the dramatic increase in prices. Only GLY knows for sure…
It will be interesting to see, but I can’t imagine they’d do anything other than try to provide a small amount of lift with foils. I’m wondering if they’ll have two mast and rigging options like they do on the 68 - cruising and regatta.I wonder if supply chain probs haven't hindered production, I have a sneaky suspicion they might've up the price a bit from what they originally was thinking they could get for them. Been a bit of a surprise that none of the 68's have gone with an outrageous colour so far..
But back to the 80, I wonder if one of the two that are in production now will go with more radical board/foil setup as in one of the pics here
https://au.yachtworld.com/yacht/2022-gunboat-80-7954708/
Sorry about that error. Our maximum displacement bridgedeck clearance is 1150mm.Bridge clearance definitely opens totally new horizons :
So its a bit Airbus with stuff from the UK?Sorry about that error. Our maximum displacement bridgedeck clearance is 1150mm.
To answer some other questions: Hulls at Fibre Mechanics and Deck/Main bulkheads at Decision/Multiplast are all done prepreg corecell/nomex and vacuum, not autoclaved, but naturally the rig components and appendages (rudders boards) will be autoclaved.
All composite components are trucked to Gunboat France for assembly and then yacht fitout. Even if we wanted to build prepreg cabability in house we are short of space, hence the outsourcing strategy. A good problem to have! Thank you for the interest and support!
Crossing the Atlantic (W to E) on a Gunboat 68. Most important take home - a boat that can sail at ~true wind speed in light winds is a dream. You get fast speeds and flat water.
On our boat we specifically looked for 10-12 knots for a passage. Good enough to easily average 6 knots of boat speed upwind or downwind and nice flat water. Friends with overloaded monos were looking for 15-20 knots to make their boats go!
