H/111 rudder bearing
George Dewey
132
Charleston, SC
And now I'm told my J/111's rudder bearing has pieces falling out of it and needs to be replaced. The boat yard has never done one, and asked me what bearing (pretty sure it's some Jaffa) and and for info on how to install it. I'll contact J Boats and CCCF but I thought I would ask here as well. It's a 2011 and I recall there is a TSB about the rudder. Something about an early J/111 sinking near Nova Scotia on her way to the UK.
Anyone have any pointrs?
Thanks guys!
slug zitski
Banned
7,495
1,612
worldwide
Hard to tell without seeing it
typically Jefa on those j boats
El Borracho
Meaty Coloso
6,956
2,899
Pacific Rim
Thanks guys!
Have the yard work closely with PYI. PYI seems to really take care and know the details of Jefa repairs. Or go to a different yard.
steele
253
Land of the locks
My 2012 J109 had JP3 bearings, and I suspect 111s from that same era have them as well. I can't figure out what would be falling out of them, the issue is more often corrosion of the aluminium housing and problems with loosening of the collar that keeps the shaft from dropping down. I agree with PYI being a great resource, I purchased my replacement Jefa bearings from them.
Good time for the Bieker 111 Rudder Upgrade.
Following is the link to the "Bieker J/111 Rudder Upgrade" string Irrational 14 referenced.
a new profile is not too expensive
cutting out the old bottom bearing and replacing with a jumbo bearing is a lot of wor
Not too expensive? Perhaps a simple fiberglass and foam blade from a mold stock…
Modern high aspect rudders with todays minimal chord lengths require proper engineering, higher end materials and even a higher skill set than most to build them so they don’t snap. Even an FT 10 rudder upgrade is around $7k last time I checked.
slug zitski
Banned
7,495
1,612
worldwide
I’m sure that a substaitial part of the rudder cost is design fee. Those guys arent cheap
the blade had finer detailing , but nothing extreme for a skilled builder
the stock reinforcement ..I guess the old stock was saved ..is evident by the extra large diameter bearing …this definitely adds cost
slug zitski
Banned
7,495
1,612
worldwide
I believe the design fee is roughly 10% of the overall cost.
Sounds Possible ..most of that stuff is almost off the shelf..a bit of tweaking on the computer, plus a few emails
the last time I had a rudder reskinned it was 6800 euro
no design fee, same stock and bearing ..it was a swan..good profile, not gran prix detailing
16000 is a lot for a performance upgrade on a small boat ….but then again a racing bottom job is not cheap….I guess it up to the customer
Roleur
787
Orcas Island
I would agree with you if it was strictly a performance upgrade. Main reason for the upgrade on a J/111 is not for performance, and looks pretty cheap compared to the boat sinking or needing to be towed from who knows where after the original rudder breaks.
slug zitski
Banned
7,495
1,612
worldwide
Strange that the designer got the rudder scantlings wrong …typically a substantial safety factor is included
the common way a rudder stock breaks is when the lower self aligning bearing freezes up and is no longer self aligning .
.point loading the stock ..keep an eye on yours, keep it lubricated
We have been extensively racing (and day sailing) J/111 hull #17, MADMEN, in SF Bay since the boat was delivered in March 2011. We have replaced the stock rudder bearing twice since then, most recently in 2021 and have had no serious issues or failure. Just a significant binding feel in the helm, which drove the haul out, and bearing replacement. Each time the lower bearing was packed with salt and grit (nasty). We are, however, aware of some J/111 rudder failures, most notably hull # 1, which was lost at sea (all aboard were rescued). One of our sister ships here SF (hull number 100 +) has experienced a rudder failure as well.
I am aware the J/111 one design is still significant for certain owners (Great Lakes, Europe, US Nationals, Worlds etc.). However, like Roleur, albeit we will not go offshore, I think, if not one design focused, the larger diameter bearing and rudder stock and optimized rudder is a great call. BTW sincere congrats to you Roleur for your Double Handed Pac Cup pursuit. You guys are awesome!
Slug zitski, thanks for providing all of the fantastic info.
