H/111 rudder bearing
George Dewey
132
Charleston, SC
PYI worked with the yard, and they told me the yard was someone they have worked with before and were confident they could handle it. Here are some pics of the completed job, and I think before there was a trim ring which is gone. The boat seems to sail fine, helm feels nice, but I wonder how much drag this will create?
longy
Overlord of Anarchy
7,195
1,388
San Diego
A flat washer isn't going to do much - it's more of a stopgap effort to prevent rudder blade from moving up & rubbing on bottom of hull. If your bearings are properly installed they should have some method to lock the post vertically
For a full race install you'll need to make a washer that fits inside the hull ID, is tapered (hole is much thicker in front) and can be glued into place (best is glue to hull, not bearing)
steele
253
Land of the locks
I don't think the ring is important for the function but works as a spacer and offers some protection for the lower bearing. It is not too hard to imagine something like monofilament line getting wrapped on the shaft and moving up into the bearing and causing havoc. The diver who changes my anodes once found over 100' of fishing line wraped around my prop, I was lucky it did not damage the lower seal on the saildrive,
longy
Overlord of Anarchy
7,195
1,388
San Diego
YMMV, but every rudder I've looked at that had a 'ring' / flat plastic washer, that washer was loose in the gap between blade & hull. Any mono could easily go above it (or below)
slug zitski
Banned
7,495
1,612
worldwide
To didn’t follow the thread
A rudder is buoyant
The washer acts as a thrust bearing to prevent the rudder from floating up and contacting the hull
George Dewey
132
Charleston, SC
A rudder is buoyant
Ug, okay I'll talk with the yard about getting this corrected.
I did email PYI and sent the pictures I posted here, asking if this looks right. Here is their reply:
Yes this looks correct.
The part I think you are asking about is the fairing piece or trim ring that covers the exposed part of the hole.
This trim ring is a detail normally done as a separate part or add-on to the bearing installation.
It is a nice finishing touch but not always done.
slug zitski
Banned
7,495
1,612
worldwide
Hmmm
The spacer is indeed a boatbuilders tool
The spacer ring defines the gap between the top of the rudder and the hull
When you build a new rudder it’s not possible to get this interface gap between the top of the rudder and the hull correct
With a new rudder you first do a dry fit .. without the spacer ring ...observe the gap between rudder and hull
You then cover the hull with a break film ,like plastic sheet, then apply a big blob of fairing compound to the top of the rudder .. then fully insert the rudder ,,, fairing compound on the top of the rudder squeezes out .. after cure you have a perfect fit.. zero tolerance gap
When the spacer is added to the rudder stock and reinserted , you now have a perfect ... 4mm or whatever gap between the top of rudder and the hull
It’s possible that production boats skip this custom detail
Also , Rudder buoyancy is a fact
longy
Overlord of Anarchy
7,195
1,388
San Diego
Rudder buoyancy is dependent on construction. Without knowing construction details one just has to guess. The production boat rudders I've removed in the water barely floated.
Many of the rudders I've removed in a yard would definitely have sunk
No way. Slug knows everything.
