Hand laminating foam core panels - any tips?
MiddayGun
384
Yorkshire
Q for the resin experts.
I want to laminate some foam core panels to replace some locker partitions and settee backs in the saloon bunks that I've had to cut access through in the boat.
For some of the bits, it will be easier to make them outside of the boat & then glass them in place.
I was planning to use this foam:
https://www.easycomposites.co.uk/easycell75-closed-cell-pvc-foam
The originals were part of a moulded in liner & were
Gelcoat
300gm/m2 CSM
450gm/m2 CSM
Foam Core (expanding polyester foam injected after moulding, about 40kg/m3)
300gm/m2 CSM
450gm/m2 CSM
Gelcoat
For making the panels I'd planned to use Vinylester resin and was thinking that 2 layers of 300gm/m2 biax each side of the foam would be close enough given that its got better properties than CSM & is a better resin.
Questions:
- Does the above look a suitable layup?
- With Vinylester do I still need a layer of CSM next to the foam & between each layer? Or is it like Epoxy and I can just the biax?
- Can I do one side at a time or will the shrinkage cause the panel to warp?
- Cut the panel to shape first & laminate it, or just laminate big panels & cut the parts out of that?
- Is it worth using peel ply with vinylester as it doesn't blush?
Cheers!
allweather
76
baltic
Well, no expert but I am curious if you have a vacuum pump available or some other method to press the panels?
As far as I understand it(and from the sandwich panels I diy) there is no need for chopped strand anywhere in your build.
Peel ply, what kind of surface finish are you looking for? In other words, if you still need to paint and require a keyed up surface, then yes.
MiddayGun
384
Yorkshire
No vacuum pump, I was hoping to avoid infusing or bagging as its a load more equipment to purchase and I'm not sure if I'd get much use out of it.
That said if its the only way to do the job properly then i'll get one.
I was thinking I could press it by covering a piece of plywood in some sort of release film & piling heavy shit on top. Always nice to hear from someone who's done it though.
Finish will most likely be a paint, I don't want gelcoat as I'll have to bond & glass these panels into place.
Zonker
4,781
Canada
For locker partitions that somebody is not leaning against, you can get away with a single layer of 300 gm/m2 each side.
For settee backs that might be bigger or heavily loaded by sails, big drunk sailors falling on them, then I would go with 2 layers x 300 0/90 or +/-45  each side.
No CSM needed.
Hmm good question. I'd say no problem if you put some weights on the top surface until the resin cures. I generally use epoxy so shrinkage is less of an issue.
++ 1 big panel and then cut pieces out of it. Laminating lots of little bits is very fiddly and the unfinished edges will have raw spikey bits of glass.
Use a jigsaw blade with carbide grit on it to cut out the pieces, even if you have to search a bit to find one. So much better than wearing out bi-metal blades.
No need for peel ply.
Laminate against a flat table that has been covered with mold release/wax. A sheet of plywood on sawhorses with a covering of cheap pressure laminate in an ugly color nobody wanted to buy ("Formica" brand name in N.America) OR a piece of particle board with melamine finish both make good surfaces. Wax both several times.
So step 1 / stack =
mold table
wax
glass layer, wetted out
foam core
weights
<let cure>
<remove from table, flip over>
step 2
mold table
wax
opposite glass layer, wetted out
       then add:
foam core with previously cured glass layer on other side
weights
I'd use 12mm / 1/2" core thickness as a bit of a guess, depending on span/fitting into existing thickness of cabinetry etc.
Cut out pieces, coat edges with thickened epoxy if they are going to be exposed. If all glassed in no need to treat edges.
MiddayGun
384
Yorkshire
Cheers @Zonker I think that basically covers everything.
Final Q, if I want to make a panel that's longer than the largest core size I can get, do I need to scarf two pieces of core together, or can I get away with butting them up to each other with maybe some thickened resin inbetween them?
Startracker
97
Van Isl.
Everything he said, except, rather than carbide grit blades, spring for the carbide toothed wood blades, I believe festool and maybe Diablo or Lennox make them now.  Much less burning, generally an equally nice easily sanded cut and long wearing. Just used one in some 1.5" solid glass actually.
SloopJonB
10,592
Great Wet North
I experimented with making non-structural panels like that using 1/8" ply and cheap pink insulation foam.
Epoxied the panels and weighted them with some old weight machine weights.
It worked great - quick, cheap, simple and stiff as 3/4" ply but less than one Lb per Sq Ft.
Way easier, cleaner, cheaper etc. than laminating glass over expensive structural foam.
This one was to fit between bulkheads so I didn't bother putting anything solid along the edges when I laid them up, just coated the foam with epoxy to seal it.
Zonker
4,781
Canada
The pink stuff is OK if you don't consider them very structural. The shear strength of that type of foam is quite low. (about 1/4-1/5 of a PVC boat building type foam).
MiddayGun
384
Yorkshire
Cheers John, I'll may try and get something like that for the bits that don't need any strength. Although that pink stuff you guys get isn't all that common over here, insulation foam is normally a minimum of 25mm thick.
For the bunk areas I'll stick with the stuff above, I don't know how much structure what was there had been providing, but I may as well make sure whatever goes in is stronger.
I'll try the carbide blades suggested above as well.
SloopJonB
10,592
Great Wet North
"Structural" wasn't even considered - strictly for panels like shelves, dividers, maybe locker doors and so forth.
I might consider an application like the door to a head compartment - with some suitable solid edging around the perimeter.
I was pleasantly surprised by the strength and stiffness it achieves - it was better than I even hoped for.
SloopJonB
10,592
Great Wet North
The thinnest I could find was 12 MM (1/2") so a 3/4" finished panel is the best you can get - too thick for many possible applications.
I did use it for a new galley counter top - laminate epoxied on the top and 1/2" coated ply on the bottom with 1/2" square cedar framing the foam in. It worked like a charm - totally solid and lighter than the 1/2" ply/laminate it replaced. The pic is not the best but it give you an idea of what can be done with this method.
I will eventually have to make new flats for my 1/4 berths - they are currently 1/4" ply with a coating of mat. I suspect my foam core idea will be an improvement on that.
Leeroy Jenkins
464
Vancouver
Butt with thickened resin is totally fine. The joint will  be stronger than the foam.
If building a box would you want to make individual panels with a solid wood edge (foam thickness X ~1")?
And if this was a box to cover the forward end of an inboard would it be louder, quieter, or no different?
Zonker
4,781
Canada
If the foam was that thick I'd just tape over the edge with 3 or 4" wide glass tape.
But nothing wrong with wood. If you want to get fancy you rout out the core ~1/2 the depth of the wood so the wood sticks out of the glass a bit. Or take the foam core, glue wood strips around the edges, then cover the panel with glass. Lots of ways to do it.
For the outboard cover - the gap is what matters. Think of noise like water leaking out. Put a gasket on the edge so it makes a good seal with whatever and it will be quiet. Have a 1/4" gap and it will be much noisier.
Also - make the box slightly bigger and line the box with sound absorbing foam. To let the outboard breathe make sure any openings are baffled so there is no direct line of sight to the noise source.
Zonker
4,781
Canada
No. PVC structural foams are fine.
Polyester eats Styrofoam like SJB showed. Epoxy does not. I suspect Vinylester eats but do not know.
MRS OCTOPUS
195
AUSTRALIA
Recently hand laminatated panels for an efficient low HP runabout. 400 DB each side of 10mm Divinicell with epoxy and peel ply.
Hand laminated and peel plied one side at a time using a  flat 200 mm drywall spatula.  Warping not a problem with the epoxy. Make sure the peel ply is in smaller sections as the peel ply can relax over a 1200 x 2400 sheet and leave a wrinkled finish.
Foam scraps joined with fairing compound and held in place with short staples shot through plastic film to keep the edges aligned while setting. Staples easily removed by pulling off the plastic complete with staple.
flip panel when set and lay up other side. Very quick and easy.
Pictures show surface finish PP still on , and a panel with joins in foam.
Zonker
4,781
Canada
Very nice work so far. What are the darker shadows in the 2nd photo?
Being a cheap bastard I would go to the fabric store and look in their remnants section for ripstop nylon in gaudy colours. Usually picked it up for $1-2/m. I used that in place of peel ply. Now this does have the possibility of contamination but any future bonding or painting surfaces always got a solvent wipe and sanding where required. If a fabric felt like it had a silicone or DWR (durable water resistant) coating I would not use it.
