Rain Man
The cabin will have a woodstove for backup, due to frequent power failures.
However, for good energy efficiency, we want to use a heat pump. The current design concept is a tri-zone mini-split with one 9K unit in the great room and a 7K unit each in the bedrooms. The bathroom will have radiant floor heat on a timer/thermostat, and the laundry/utility room a small baseboard heater for the rare times it will be used.
Outside air temperature averages out to no colder than -5 C at night in winter, but there might be a few nights per year of -20 C where a heat pump will struggle.
The heat pump will be used for aircon in summer, but not often.
The problem is what to do with those few -20 C nights. Are we better to stay with the mini-split (cheap, easy to install) and use baseboards for backup, or go with a ducted system and electric furnace which uses the heat pump coil and resistive backup so we can have heat even when it is -20 C? We will be there for some of those nights and could use the woodstove for backup, but the cabin will be empty on some very cold nights as well. For those, we just don't want the pipes to freeze.
I have also read that there are now mini-splits available that will still work well in -20? Anyone know if those systems really work?
TIA
